RLC Circuit- Find average power in circuit
The discussion focuses on calculating the average power in an RLC circuit with a power factor of one at a frequency of 3 x 10^3 Hz. Given the rms voltage of 139 Volts and rms current of 37.1 amps, the inductive reactance is 47 Ohms. To find the average power at 0.78 times the resonant frequency, users must determine the inductance and capacitance using the relationships between reactance and frequency, and apply the formula Pav = Vrms Irms cos(φ) where cos(φ) equals one.
  • Understanding of RLC circuit theory
  • Familiarity with RMS voltage and current calculations
  • Knowledge of reactance formulas: XL = 2πfL and Xc = 1/(2πfC)
  • Ability to calculate resonant frequency: f_res = 1/(2π√(LC))
  • Calculate inductance (L) and capacitance (C) using given reactance values
  • Learn to derive phase angle φ from reactance and resistance
  • Explore phasor diagrams for RLC circuits to visualize voltage and current relationships
  • Study the impact of varying frequency on average power in RLC circuits
Electrical engineering students, circuit designers, and anyone involved in analyzing RLC circuits and power calculations.
yankeekd25
When the power factor of RLC circuit is equal to one, the frequency of the voltage source is 3 x 10^3 Hz. The rms value of the voltage source is 139 Volts and at a frequency of 3 x 10^3 Hz, the rms current in the circuit is 37.1 amps. If the inductive reactance at 3 x 10^3 Hz is 47 Ohms, what is the average power of the circuit in Watts at 0.78 times the resonant frequency of the circuit?
Pav = Vrms Irms cos (|)
Vrms= V/sqrt 2
Irms= I/sqrt 2
V= XL I
V= Xc I
XL= 2 pi f L
Xc= 1/ 2 pi C
Res freq= 1/2pi 1/ sqrt (LC)
I'm going in circles with this problem. Given the RMS value of the voltage and current, I tried to find the max voltage and current, and then plug that into V=XL I and V= Xc I to find XL and Xc, but I am probably wrong.
I guess I need to use the XL and Xc for each at the given frequency, to find both L and C to find the resonance frequency, multiply that number by .78, and then plug everything back into something?
Can someone please help me sort out this problem? Thanks
Can someone please help me out and get me started in the right direction please?
If the power factor cos(\varphi) = 1, then the phase angle between the Vmax and Imax vectors in the phasor diagram must be \varphi = 0. This means that Vmax vector has no y component, which means XL = XC. Since we know the inductive reactance and the resonant frequency, we can find the inductance and capacitance of the circuit. Also, at the resonant frequency, the impedance z = sqrt( R^2 + (XL -XC)^2 ) = sqrt( R^2 ) = R, so you can use Vrms and Irms to find R ( Vrms = Irms*z = Irms*R ). Then, you can find the reactances and impedance at the new frequency, draw the phasor/impedance diagram, find the new phase angle \varphi between V and I ( \varphi = tan^(-1)( (XL -XC) / R), and use those to calculate Pav.
  • · Replies 21 ·
