Rms speeds at 20 degrees celcius of atoms of helium
The discussion revolves around calculating the root mean square (rms) speeds of helium atoms at 20 degrees Celsius and determining the temperature at which oxygen (O2) achieves an rms speed of 11.2 km/s, the escape speed from Earth. Additionally, it addresses the change in internal energy and heat absorbed for one mole of an ideal monatomic gas heated from 0 to 100 degrees Celsius under constant volume and constant pressure conditions. Participants emphasize that complete solutions to these problems are not provided on the forum, directing users to other resources for homework help. The conversation highlights the importance of understanding the underlying physics concepts rather than seeking direct answers.
thomas
1. Calculate the rms speeds at 20 degrees celcius of atoms of
helium (4u)?
2. The escapte speed from the surface of the Earth is 11.2 km/s. Find at what temp. the following gas (O2) have this value as the rms speed?
3. One mole of an ideal monatomic gas is heated from 0 degrees celcius to 100 degrees celcius. Find the chnage in internal energy and the heat absorbed, given that the process takes place under the follwoing condition:
(a) constant volume
(b) constant pressure
I see, they are very pretty. Now, what do you want?
Help pls
I would like to have some solution for these questions thank you.
Thomas, you're at the wrong website. You want:
http://www.wedoyourhomeworkforyou.com :smile:
Seriously, please read the https://www.physicsforums.com/showthread.php?t=4825 at the top of this Forum. We don't do complete solutions here.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
