Scrum
- 5
[SOLVED] Rocket Height (Motion in streight line)
Hey I'm 75% sure i have the correct answer, but i have to turn it in tomorrow and it's a lot of points so i just want to make sure I'm going it right.
A rocket, initially at rest on the ground, accelerates straight upward from rest with constant acceleration 49.0 . The acceleration period lasts for time 9.00 until the fuel is exhausted. After that, the rocket is in free fall.
Find the maximum height ymax reached by the rocket. Ignore air resistance and assume a constant acceleration due to gravity equal to 9.8 m/s^2 .
Sorry if this doesn't look so hot, the formulas were given to me with lost of sub things and i don't know how to make them look good on forums, I'm trying the Latex for the first time
y(t)= y_{i0} + v_{i0}t + (at^{2})/2
v(t)=v_{i0} + at
The i0 should be at the bottom and it means initial at time zero but you probably already knew that.
y(t)= y_{i0} + v_{i0}t + (at^{2})/2 for 0 < t < 9
Declare variables and set them equal to values in the problem.
y_{i0} = 0
v_{i0} = 0
a = 49
formula for postion after 9 seconds of acceleration.
y(9)=(49(9)^{2})/2
solve to a number = 1984.5 m at t = 9
Now calculate the velocity at time = 9.
v(t)=v_{i0} + at
v(9)=0 + 49(9)
v(9) = 441 m/sCreate a new position fuctionfor time after 9 to the time where the rocket is at 1984.5.
y(t)= y_{i0} + v_{i0}t + (at^{2})/2 for 9 < t
Declate Variables
y_{i0} = 1984.5m
v_{i0} = 441 m/s
a = -9.8
t = (t-9) (offset time to account for the first part)
y(t)= 1984.5 + 441(t-9) + (-9.8(t-9)^{2})/2
I don't know how to do this properly, but i know if i sub in an x for (t-9) and solve for the x intercepts and then add them and divide by two i will get the time that it's at the top, and then plug that time back into the function and i should get the answer. to avoid the quadratic forumla I'm putting it into grapher on my mac.
and get something around 3*10^5 ?
v(t)=v_{i0} + at
y_{i0} = 0
v_{i0} = 0
a = 49
y(9)=(49(9)^{2})/2
v(t)=v_{i0} + at
v(9)=0 + 49(9)
Declate Variables
y_{i0} = 1984.5m
v_{i0} = 441 m/s
a = -9.8
