Rocket Losing Mass: Finding Ratio of Max Momentum to Initial Mass
In summary, the maximum momentum of a rocket is reached when its mass is divided by its initial mass.
Karol
1,380
A rocket launches from a space base at 0 velocity and looses mass at constant rate C. what is the ratio between the rocket's mass at maximum momentum to it's initial mass.
Newton's second law: ##F=dP=\frac{d(mV)}{dt}##
Conservation of momentum: ##m_1v_1=m_2v_2##
To find maximum momentum i differentiate momentum:
$$F=dP=\frac{d(mV)}{dt}=m\frac{dV}{dt}+V\frac{dm}{dt}=ma+V\cdot C=0$$
$$m(t)a(t)=-C\cdot V(t),\ m=M_0-C\cdot t\rightarrow (M_0-C\cdot t)a(t)=-CV(t) \rightarrow t=\frac{M_0}{C}+\frac{V(t)}{a(t)}$$
Both a(t) and V(t) are functions of T and i can't solve for t.
I am not told anything about the velocity the mass leaves the rocket.
It is v0, you can assume that it is constant (otherwise the problem is not solvable). The value does not matter, as the velocity will cancel out in the calculations later.
haruspex said:
There seems to be missing information. You need to know how much of the initial mass is fuel.
You don't need that. Just assume that there is enough fuel to reach the point of maximal momentum (we know that there is, because the rocket has a constant mass flow rate).
Yes, I realized my blunder but didn't manage to delete before you immortalised it.
Karol, expanding F as ##\dot P = m\dot v + \dot mv## is never a good idea. It would be true of a body in which mass is being created or destroyed without affect its velocity. See section 6 of https://www.physicsforums.com/insights/frequently-made-errors-mechanics-momentum-impacts/.
Assume thrust, ##F=m\dot v##, is constant.
If the velocity Vr of the expelled gases is constant and the mass per second is also constant then ##\delta m\cdot V_r=F\cdot\delta t## and since ##\delta t## is constant then F, the force exerted on the rocket is constant, is that right?
But if so i can't take ##m\dot v## as constant since m changes and ##F=\dot P = m\dot v + \dot mv## and there is another member ##\dot mv##.
But maybe i don't understand F. i think your F in ##F=m\dot v## is the same F in mine: ##F=\dot P## and is the total force applied on the rocket, so how can they be the same? they have 2 different equations, your is shorter than mine.
Conservation of momentum between the gases and rocket:
$$0=m\cdot dV+dm\cdot V_r\rightarrow \int_0^V dV=-\int_{M_0}^m \frac{dm}{m}\rightarrow V(t)=ln\left( \frac{M_0}{m} \right)=ln\left( \frac{M_0}{M_0-Ct} \right)$$
$$P=m(t)V(t)=(M_0-Ct)ln\left( \frac{M_0}{M_0-Ct} \right)$$
I differentiate P in order to find maximum momentum:
$$\dot P=-Cln\left( \frac{M_0}{M_0-Ct} \right)+\frac{(M_0-Ct)^2}{M_0}=0$$
$$ln\left( \frac{M_0}{M_0-Ct} \right)=\frac{(M_0-Ct)^2}{CM_0}$$
I can't solve
The expressions for P(t) and its derivative look more complicated than they should.
Can you find P(V)? Maybe that is easier.
I can't solve
You lost a factor Vr, but it doesn't matter - just makes it dimensionally wrong.
You've differentiated the log function incorrectly. You should not end up with a quadratic.
How? i know only P=m(t)V(t), how to make P(V)?
$$0=m\cdot dV+dm\cdot V_r\rightarrow \int_0^V dV=-V_r\int_{M_0}^m \frac{dm}{m}\rightarrow V(t)=ln\left( \frac{M_0}{m} \right)=V_r\cdot ln\left( \frac{M_0}{M_0-Ct} \right)$$
$$P=m(t)V(t)=V_r(M_0-Ct)ln\left( \frac{M_0}{M_0-Ct} \right)$$
I don't know where i made the mistake:
$$P=m\cdot ln\left( \frac{M_0}{m} \right), \quad \dot P=-Cln\left( \frac{M_0}{m} \right)+m\frac{m}{M_0}$$
I differentiated in a different way:
$$P=ln\left( \frac{M_0}{m} \right)^m\rightarrow \dot P=m\left( \frac{M_0}{m} \right)^{(m-1)}\cdot\left( \frac{m}{M_0} \right)^m=\frac{m}{M_0}$$
$$\dot P=0\rightarrow M_0=Ct \rightarrow t=\frac{M_0}{C}$$
The mass at P'=0 is 0, so it doesn't help
The power of m is inside the log, not outside. You mixed that somehow in the other approach.
You know V(m), you can convert this to m(V). Then P(V)=m(V)*V, and that expression has a nice derivative.
You are differentiating ln(M/m) incorrectly. Write it as ln(M)-ln(m), then try. What's the derivative of ln(x) wrt x?
It's inside:
$$P=ln\left( \frac{M_0}{m} \right)^m \equiv ln\left[ \left( \frac{M_0}{m} \right)^m \right]$$
I take again the derivative:
according to ##\left( u^v \right)'=vu^{v-1}\dot u+u^vln(u)\dot v##
$$\left[ \left( \frac{M_0}{m} \right)^m \right]'=...=-\frac{M_0^m}{m^m}\left( 1+Cln\left( \frac{M_0}{m} \right) \right)$$
$$\dot P=-\frac{m^m}{M_0^m}\cdot \frac{M_0^m}{m^m}\left( 1+Cln\left( \frac{M_0}{m} \right) \right)=-1-Cln\left( \frac{M_0}{m} \right)$$
$$\dot P=0\rightarrow ln\left( \frac{M_0}{m} \right)=-\frac{1}{C} \rightarrow t=\frac{M_0 \left( 1-\sqrt[C]{e} \right)}{C}$$
The mass at time t of maximum momentum:
$$m=M_0-Ct=M_0 \sqrt[C]{e}$$
The ratio to the initial mass M0 is therefor ##\sqrt[C]{e}## but that's incorrect
You don't have uv', you have ln(uv). Your outer derivative would be the log, then you get the exponent as inner derivative, and then the fraction as another step. There is no point in making it that complicated.
Honestly, I never really learned this topic, and I know that most of my classmates did not. So I decided to do some reading and make an attempt at solving this problem in detail. Please take a look at my solution and let me know what you think.
$$V(m)=ln\left( \frac{M_0}{m} \right),\quad P(m)=mV(m)=m\cdot ln\left( \frac{M_0}{m} \right)$$
$$\dot P=ln\left( \frac{M_0}{m} \right)-m\frac{m}{M_0}\cdot \frac{1}{m^2}=ln\left( \frac{M_0}{m} \right)-\frac{1}{M_0}$$
$$\dot P=0 \rightarrow e^{\left( \frac{1}{M_0} \right)}=\frac{M_0}{m} \rightarrow m=\frac{M_0}{\sqrt[M_0]{e}}$$
And again it's not correct
Karol, could you post the correct answer?
$$P=m\cdot ln\left( \frac{M_0}{m} \right)=m(ln \: M_0-ln\: m), \quad \dot P=ln \: M_0-ln\: m-\frac{1}{m}$$
$$\dot P=0\rightarrow ln \: M_0=ln\: m-\frac{1}{m}$$
I can't solve.
The possible answers are: ##\frac{1}{2},\quad \frac{1}{3},\quad \frac{1}{e},\quad \frac{1}{\pi},\quad \frac{1}{4},\quad ##
I came up with 1/e if you would like to take a look at my work. I'm somewhat confident I got there the right way. :smile:
$$P=ln\left( \frac{M_0}{m} \right)^m,\quad \dot P=\frac{m^m}{M_0^m}\cdot m \left( \frac{M_0}{m} \right)^{m-1}\cdot \frac{-M_0}{m^2}=1$$
Incorrect
That's not what I suggested (also applies to post 17 which was not there at the time I wrote this post). Also, you got the derivative wrong again, see the mismatching units. You can follow haruspex' advice if you want to keep the mass instead of the velocity, or use the velocity and get rid of the mass as I suggested. Using the same wrong derivative over and over again does not help.
@Wily Willy: Please do not post full solutions, this is against the forum rules.
Karol said:
$$P=m(ln \: M_0-ln\: m), \quad \dot P=ln \: M_0-ln\: m-\frac{1}{m}$$
Better, but this time you dropped a factor m in that step.
$$P=m\cdot ln\left( \frac{M_0}{m} \right)=m(ln \: M_0-ln\: m), \; \dot P=ln \: M_0-(ln\: m+1)$$
$$\dot P=0\;\rightarrow\; ln \: M_0-(ln\: m+1)=0\;\rightarrow\; m=e^{(ln\:M_0-1)}=\frac{M_0}{e}$$
That's correct i think, according to @Wily Willy
$$0=m\cdot dV+dm\cdot V_r\;\rightarrow m\int^V_0 dV=V_r\int^{M_0}_m dm\;\rightarrow mV=V_r(M_0-m) \;\rightarrow m=\frac{M_0 V_r}{V_r+V}$$
$$P(V)=m(V)V=\frac{V\cdot M_0 V_r}{V_r+V},\; \dot P=\frac{V_r}{(V_r+V)^2},\;\dot P=0$$
It can't be
That's it.
Yes but what about P(V) post #21?
The step in the first right arrow in post #21 looks wrong to me. m is a variable, you can't take it outside ##\int m.dV##.
So how to get P(V)? i can't integrate ##\int^V_0 m(V)dV##
The first thing that catches my eye is that momentum should always have units of kg(m/s). You are missing that when you start here. It does not effect your solution because it would be canceled by division once you set the derivative equal to zero.
Karol said:
P=m⋅ln(M0m)=m(lnM0−lnm),P˙=lnM0−(lnm+1)
This is right. (Never-minding the velocity.)
Karol said:
P˙=0→lnM0−(lnm+1)=0→m=e(lnM0−1)=M0e
And this is right. Congrats! You know most people consider rocket equations the hardest part of introductory mechanics, so if you can handle this you know you can handle anything else!
You can get the velocity by going back and differentiating the total momentum of the rocket and the gas. I would suggest not using the notation C for the rate that the fuel is burnt. Just keep in mind that the total momentum is a constant, the velocity of the gas is a constant, and that the change in the mass of the rocket is equal and opposite to the change in the mass of the gas.
Okay, as you found the solution we can explore alternatives with more help. Here is the velocity calculation I suggested:
P=m*V
We know from post #4 that ##V=V_r \ln \left(\frac{M_0}{m}\right)##, solving this for m gives ##m=M_0 \exp\left(\frac{-V}{V_r}\right)##
Therefore,
$$P=M_0 V \exp{-V/V_r}$$
$$\dot{P} = M_0 \exp\left(\frac{-V}{V_r}\right) \left(1-\frac{V}{V_r}\right)$$
It is easy to see that this becomes zero at V=Vr. Plugging it back into the equation for m, we get m=M0e-1.There is a way to get the result V=Vr without calculation just based on momentum conservation: the change of momentum of the rocket is given by the "momentum exhaust". This is zero exactly when the exhaust has zero velocity. As it moves with -Vr relative to the rocket, this happens at V=Vr.
Likes Karol
Wily Willy said:
You can get the velocity by going back and differentiating the total momentum of the rocket and the gas... Just keep in mind that the total momentum is a constant, the velocity of the gas is a constant, and that the change in the mass of the rocket is equal and opposite to the change in the mass of the gas.
The result is as mfb said:
$$m(V)=M_0e^{\left( -\frac{V}{V_r} \right)}\left( 1-\frac{V}{V_r} \right)$$
But how to get to that with your method?
I tried this way:
From a coordinate system moving at the momentary velocity V the change in momentum of the gases and rocket equals zero: ##0=m\cdot dV+dm\cdot V_r##
But i can't differentiate it any further, i think mathematically it's not allowed.
I try to take the total momentum in an inertial frame but i don't know which mass to take for the gases: should i sum up all the gases that were expelled from the beginning or the infinitesimal amount? and the gases from different times have different velocities also.
So i am left with the infinitesimal amount:
$$\dot P=\frac{d(mV+dmV_r)}{dt}$$
But i can't differentiate that either
My way is really the same as mfb's. I was trying to be "less direct" in my advice and keep in line with the forum's rules.
Anyway, I was just saying that determining a function for momentum with velocity as the only variable might be easier if you just started from the beginning with careful notation of the variables involved.
  • #31
Karol said:
##0=m⋅dV+dm⋅V_r##
Well, no, you can't differentiate it because in full it is ##0=dP=m⋅dV+dm⋅V_r##. You can divide through by dt to give ##0=\dot P=m⋅\dot V+\dot m⋅V_r##, whence ##(m_0-Ct)\dot V=C V_r##.
  • #32
But ##\dot m=-C## and ##\dot m V_r=-C\cdot V_r\rightarrow 0=\dot P=m⋅\dot V+\dot m⋅V_r=C\cdot V_r-C\cdot V_r=0##
  • #33
I'm finding the notation confusing. I'll write Ptot for total momentum and Pm for the momentum of the rocket mass. And I'll write tf for the time at which the rocket momentum is maximised.
##P_m=mv##, ##\dot P_{tot}=0=m\dot v -Cv_r##, ##\dot P_m(t_f)=0=\dot m(t_f)v(t_f)+m(t_f)\dot v(t_f)=-Cv(t_f)+ Cv_r##.
So ##v(t_f)=v_r##, which should not surprise. It says the rocket's momentum is maximised when the exhaust being emitted at that time has zero momentum.
But this doesn't get us to the answer. To get an answer we need to solve a differential equation. There may be an easier way, but one way is to go back to the basic rocket equation ##\dot P_{tot}=0=m\dot v -Cv_r=(m_0-Ct)\dot v -Cv_r##. Rearrange and integrate wrt t.
  • #34
$$(m_0-Ct)\dot v -CV_r\;\rightarrow \dot v=\frac{CV_r}{m_0-Ct}\;\rightarrow \int\dot v=\int\frac{CV_r}{m_0-Ct}$$
$$v=CV_r\int^t_0\frac{dt}{m_0-Ct},\;m_0-Ct\triangleq u,\; dt=-\frac{du}{C}, \; t=0\rightarrow u=m_0$$
$$CV_r\int^{\frac{m_0-u}{C}}_{m_0}\frac{-du}{C\cdot u}=-V_r\left[ln\:u\right]^{\frac{m_0-u}{C}}_{m_0}=V_r ln\left( \frac{Cm_0}{m_0-u} \right)=V_r ln\left( \frac{m_0}{t} \right)$$
It's incorrect and doesn't lead me to the answer of what's m(v). also i am not sure i am allowed to make the step: ##\int\dot v=v##
  • #35
Karol said:
$$CV_r\int^{\frac{m_0-u}{C}}_{m_0}\frac{-du}{C\cdot u}$$
the upper bound on the integral is wrong. It contains two errors. One could have been found by checking the dimensional consistency.
