Rocket Velocity: γ = 4, v = √15/4c
billy92
If a rocket is traveling past the Earth at speed v, and the time interval measured by the astronaut is four times smaller than the time interval measured by an observer on the Earth. What is the value of v
I have attempted the solution and got:
Δt=γΔt'
Where i believe that gamma will be 4.
From this i used:
γ=\frac{1}{\sqrt{1-\frac{v^{2}}{c^{2}}}}
From this i managed to calculate v=\frac{\sqrt{15}}{4}c
However i am slightly concerned about how large this value is for a rocket but cannot seem to see any other solution to this problem. Any suggestions?
Thanks
Yes, you are right, it takes very large values of velocity to get appreciably large values of gamma. You got the right answer.
Thanks for the quick reply.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
