Rope tension on a mountain climber
  • Thread starter Thread starter Firestrider
    Rope Tension
The discussion focuses on calculating the tensions in the rope on either side of a mountain climber weighing 586 N, who is resting between two cliffs. The angles given are α = 60.0° and β = 88.0°, leading to the equations T_L*cos(60) + T_R*cos(88) = 0 and T_L*sin(60) + T_R*sin(88) = 586N. After manipulating these equations, the calculated tensions are T_R = 552.31N and T_L = 38.66N. There is a suggestion to visualize the forces using right-angle triangles to ensure proper resolution of the tension components. Accurate understanding of the angles and their relationship to force components is critical for solving the problem.
Firestrider
A mountain climber, in the process of crossing between two cliffs by a rope, pauses to rest. She weighs 586 N. As the drawing shows, she is closer to the left cliff than to the right cliff, with the result that the tensions in the left and right sides of the rope are not the same. Find the tensions in the rope to the left and to the right of the mountain climber. (From the figure α = 60.0° and β = 88.0°.)
N/A
-T_L*cos(60) + T_R*cos(88) = 0
T_L*cos(60) = T_R*cos(88)
T_L = T_R*cos(88) / cos(60)
T_L = 0.07*T_R
0.07*T_R*sin(60) + T_R*sin(88) = 586N
T_R = 586N / (0.07*sin(60) + sin(88)) <-- This might be where I'm confused
T_R = 552.31N
T_L = 38.66N
First of all, both angles seem to be measured from the vertical. Therefore, I think that the vertical components of the tensions are scaled by cosine factors, and the horizontal components are scaled by sine factors. You should draw a right angle triangle representing the force vector resolved into its components (one for each tension) in order to be sure.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
