Rotate the area bound by the following lines around the x-axis.
kashiark
y = x^2+1, y = -x^2+2x+5, x = 0, x = 3
None that are uniform enough to put here considering I'm fairly sure it's not washer...
The first two equations are not lines. Their graphs are parabolas.
What have you done so far? Have you sketched a graph of the region being rotated?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
