Rotation Matrix: Calculating Angle & Direction of Rotation
The discussion revolves around a problem involving rotation matrices and the determination of the angle and direction of rotation based on a given matrix. The original poster presents a matrix and seeks assistance in finding the corresponding angle and direction of rotation.
  • Participants discuss the relationship between the elements of the rotation matrix and trigonometric functions, questioning how to derive equations for the angle theta from the matrix components. There are attempts to clarify the correct equations and notation related to the rotation matrix.
Some participants have provided guidance on using the definition of equality of matrices to derive equations for theta. There is an ongoing exploration of how to determine the direction of rotation, with references to conventional definitions of positive and negative angles.
Participants note some ambiguity in the question regarding the direction of rotation, as the same angle can correspond to both clockwise and counterclockwise rotations depending on the sign of theta.
breen155
Hey guys, I'm not sure if this bit is relevant but the first part of the question is... 'The diagram shows a triangle with vertices O, A(1,2) , B (0,2). The question I need help with is 'Each of the following matricies represents a rotation about the origin, Find the angle and direction of rotation in each case'
(1/2 -[tex]\sqrt{3}[/tex]/2)
([tex]\sqrt{3}[/tex]/2 1/2)
Imagine its one big set of brackets around the above matrix not 2 smaller ones :)
I'm also not sure whether these are of relivance but x' = ax + cy and y' = bx + dy
also I have the matrix
cos[tex]\theta[/tex] -sin[tex]\theta[/tex]
sin[tex]\theta[/tex] cos[tex]\theta[/tex]
I have been messing about with this for a while attemting to sub in co ordinates to the x' equations and y' equations but I feel I am getting nowhere. I would appreciate any help.
Thanks in advance guys
Breen155
[tex]\begin{pmatrix} a & -b \\ b & a \end{pmatrix} = \begin{pmatrix} cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta) \end{pmatrix}[/tex]
[tex]a = \frac{1}{2}[/tex]
[tex]b = \frac{\sqrt{3}}{2}[/tex]Can you use the definition of equality of matrices to get two equations for theta?
not too sure what you mean sorry I only started teaching this to myself this morning :S erm... is it costheta - sin theta = .5 and sintheta + costheta = sqt3/2 ?
I slipped up on my notation. I fixed my last post. Try to get the equations again because they aren't right. Remember, get them by using the definition of equality for matrices.
costheta = .5 and sintheta = sqrt3/2 ? :)
correct. Now you just need to find theta.
theta is 60 degrees but how do i tell the direction of rotation, clockwish or anticlockwise ? :) (thanks for the help so far btw)
Remember that a positive theta corresponds, by convention, to a counterclockwise rotation. If it were a clockwise rotation of 60 degrees, then theta would be -60 degrees. This is equivalent to a counterclockwise rotation of 300 degrees, and you see that the sine and cosine of 300 degrees is exactly equal to the sine and cosine of -60 degrees. Of course, this means the question is a bit vague, since you can change the direction of rotation just by changing the angle. If you have both a direction with a correct angle, however, it should be fine.
Ok I understand now. Thanks for all the help guys
