Rotation of a body around which axis
When torque is applied to a body, it typically rotates around its center of mass, but the specific axis of rotation depends on the orientation of the applied torque. If no net force is acting on the object, it will rotate about its center of mass without translating. However, if a net force is applied alongside the torque, the body will experience both rotation and linear movement. The axis of rotation may not align with the torque axis unless the torque is applied along one of the principal axes of inertia. Thus, the relationship between torque, angular momentum, and the axis of rotation can be complex, particularly for irregularly shaped bodies.
jd12345
When i apply torque on a body, it will rotate around whcih axis? I guess its the axis along centre of mass but i don't know why?
Also if the answer is centre of mass what will be the orientation of the axis- I mean there are infinite lines passing through a single point so which of those axis will be the one around which body rotates?
You can always describe the movement of a rigid body as a rotation around its center of mass (with a certain orientation of the angular momentum) plus a velocity of the center of mass (in some direction).
If you apply a torque without any net force (which means that the sum of forces (not torques!) is 0) to an unmoved object, it will begin to rotate at the position where it was before. If you apply a torque with a net force (for example, kick one side of the object), it will do a combination of rotation and global movement in the direction of the kicking force.
The same as the axis of your torque (F x r).
This statement is not true in general. An irregularly shaped body is described by a tensor of inertia, which means that the body will not necessarily rotate around the axis defined by the torque. The two axes will only coincide if the torque is applied along one of the principle axes. Otherwise, the angular momentum will be along the axis of the torque, but the angular velocity will be around a different axis, as described by the equation L = I w.
I meant the axis of angular momentum with this reply.
Maybe I should have said this explicitly.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
