hjcrbwg
- 2
I am making a hanging mobile which needs to be done mathematically by calculating torque. The problem is, I can't seem to figure out how to solve for the distance.
You see, all of the problems we did in class talked about finding mass, but to do this project, I already know the mass, I just need to know the distance between the objects that are hanging.
Note: 0.0284 kg is the weight of the rod that is holding up the objects and the string holding the rod up is in the center of the rod, which is why the force up is the same distance away from the pivot point as the rod.
Here is what my teacher gave me to work on this:
1. Forceup = Forcedown
2. τclockwise = τcounter clockwise
3. Use an object as the pivot point if there is more than one object to solve for.
Here is what I filled in those steps:
1. Forceup = (2.3814 kg + .0452 kg + .0878 kg + 0.0284 kg)9.8 m/s2 = 3.96312 N.
2. 2.3814 kg(9.8 m/s2)(0 m.) + 0.0284 kg(9.8 m/s2)(.125 m.) + 0.0878 kg(9.8 m/s2)(x m.) + 0.0452 kg(9.8 m/s2)(y m.) = 3.96312 N.(.125 m.)
which is, if my math is correct:
0.03479 Nm. + 0.86044 N (x m.) + 0.44296 N (y m.) = 0.49539 Nm.
So my problem lies here: what do I do with the two different variables? I don't have a second equation nor do I know of a second equation that I can use to calculate the distance needed between them. What can I do to make this work?
EDIT: Here is what the structure looks like: a string is holding up a rod from the middle of the rod so that the rod will be level when held from the string. There are three objects hanging from that rod, and the pivot point is the heaviest of the hanging objects.
