Rotational Dynamics: Min Initial Velocity of Inelastic Sphere on Cubical Plate
The discussion focuses on determining the minimum initial velocity of an inelastic sphere needed to successfully roll over a cubical plate. Key concerns include whether the sphere will exhibit pure rolling after impact and how its linear motion is affected by the inelastic nature of the sphere. The sphere is conceptualized as a clay mold that pivots about a point on the plate, given that the plate's height is less than the sphere's radius. The problem involves energy conservation, where the sphere must have sufficient kinetic energy to overcome the gravitational potential energy increase when rolling over the plate. The main challenge lies in accurately calculating the sphere's velocity after impact and the resulting energy transformations.
Mandeep Deka
An inelastic uniform solid sphere of radius 'R' is sliding without rolling over a frictionless ground with a uniform velocity 'v'. A cubical plate of height r (r<R) is fixed on the ground and the sphere impinges upon the cubical plate and rolls over it. What is the minimum initial velocity 'v' of the sphere, for it to be able to impinge upon the plate.
What is basically confusing me is:
i. whether the sphere will show pure rolling after impinging upon the plate?
ii. will it stop its linear motion after striking? (because the sphere is said to be inelastic), but then it can't roll over the plate!
iii. if the sphere rolls then without showing pure rolling, how am i supposed to find the answer coz there will be more variables than equations?
please help me understand what actually happens!
In this question, the inelastic ball, you can think of it as a clay mold, will have the a point on the ball getting stuck on the plate. And it will pivot about that point. The reason why it can pivot is because r is smaller than R, so the centre of mass of ball, which is carrying momentum, will cause a torque.
If r=R, this is no torque, since there is no distance from centre of mass to pivot. Anything after the rotation is over is not required by the question. And cannot be determined accurately anyway from the information given.
i understand that since r<R, the sphere would pivot about that point. But what will happen after that?? How will we find out the min velocity for the ball to be able to just roll over the plate??
Thats a energy conservation problem. It must have enough kinetic energy to overcome the increase of gravitation potential energy which will result in a lost of kinetic energy.
IF you say so, what velocity shall i consider the sphere to move after bumping up??
i mean, i equate the kinetic energy of the sphere initially, with the change in the gravitational potential energy plus some kinetic energy( either linear or rotational or both). What would that be then?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
