Understanding the Relationship Between Wheel Rotation and Turning Difficulty
In summary, the conversation discusses the concept of turning a car's wheel at high speeds and the factors that affect this. The discussion includes the differences between cars and motorcycles, the setup of a car's steering, and the various forces at play such as caster angle, momentum, and contact patch deformation. The conversation also mentions the use of diagrams to understand how these forces work and the importance of caster in the steering process.
Polyrix
Hi guys,
I have a question. I have lived life in the apparent belief that if a car is moving at a fast enough speed, turning it's wheel becomes increasingly difficult. Could somebody explain that concept to me? I assume it has something to do with the angular momentum of the wheel to make the rotation?
Thank you. Also, please offer any advice on how I can quantify the information... I am doing an analysis of a car.
Thank you.
It's much simpler if you look at a motorcycle to start. There, you must lean left to turn left. In a car, there's a whole bunch of stuff to consider. The car may be set up to understeer or oversteer for example. And, you have to look at the camber angle, etc, etc. Start with motorcycles.
Unfortunately, its the assignment. I'm getting rediculous values.. around 700 for moment of inertia, around 500 for angular acceleration, resulting in a torque that's... really, really large. I'm assuming those are probably wrong? I'm doing this all on qualitative observation of a tape.
The momentum of the auto acts on the caster angle to straighten the wheel out. Heavier and faster moving autos will have a stronger self-straightening torque on the steering axis.
Do you have diagram of auto's front-suspension with steering arm? The offset of the steering arm from steering-axis will give you leverage. The steering-axis inclination will also result in another offset called scrub-radius that affects the force required to turn the wheel as well.
In addition to the caster, at higher cornering forces, you also have contact patch deformation related to slip angle that also generates an opposing torque to steering inputs.
What's interesting is that if there where no caster (and if it is at low speeds with no contact patch ;) ) then the wheels will not torque back, which seems counter to experience. But in everyday experience there is always a caster, no matter how small.
1. What is rotational dynamics?
Rotational dynamics is a branch of physics that studies the motion of objects that rotate or spin, such as tires. It involves understanding the forces and torques acting on rotating objects and how they affect the object's motion.
2. How do tires rotate?
Tires rotate due to the frictional forces generated between the tire and the road surface. When the car is in motion, the tire's contact patch with the road experiences a force called the frictional force, which causes the tire to rotate and move the car forward.
3. What factors affect the rotational dynamics of tires?
There are several factors that can affect the rotational dynamics of tires, including the shape and size of the tire, the material it is made of, the amount of air pressure inside the tire, the surface of the road, and the speed and direction of the vehicle.
4. How does the tread pattern of a tire impact its rotational dynamics?
The tread pattern of a tire plays a crucial role in its rotational dynamics. The grooves and patterns on the tire's surface help to channel water and debris away, providing better traction and reducing the risk of skidding. Different tread patterns are designed for different purposes, such as all-season, winter, or performance driving.
5. Why is understanding the rotational dynamics of tires important?
Understanding the rotational dynamics of tires is essential for ensuring safe and efficient driving. It allows engineers to design tires that provide optimal performance in various driving conditions, such as wet or dry roads. It also helps drivers to understand how their actions, such as braking or accelerating, can affect the tire's rotation and overall vehicle motion.
