HT3
- 23
- 0
Rotational Kinematics HELP!?
I desperately need help with two rotational kinematics problems. I do not know what to do in both cases. If someone could be kind enough to go through a solution for me to see it would be very helpful in understanding the problem. Please try and be detailed in your answer as I really want to understand how it is solved.
Answer: 12.5s
2) A fan blade whose angular acceleration is a constant 2.00 rad/s^2 rotates through an angle of 285 radians in 11.0s. How long did it take the blade starting from rest to reach the beginning of the 11.0s interval?
Answer: 7.45s
Newtonian rotatational formulae.
no idea i did the last 20 problems no problems but these 2 are stumping me.
1) A spinning wheel on a fireworks display is initially rotating in a counterclockwise direction. The wheel has an angular acceleration of -4.00rad/s2. Because of this acceleration, the angular velocity of the wheel changes from its initial value to a final value of -25.0rad/s. While this change occurs, the angular displacement of the wheel is zero. Find the time required for the change in the angular velocity to occur.Answer: 12.5s
Answer: 7.45s
