Rotational kinetic energy explaination
92 replies · 41K views · last reply
sushruth said:
I have proven that the energy has not increased...ofcourse the sting does work because the centripetal force is acting inwards and the ball is pulled inwards...how does that mean that the string does no work?...
centripetal force does no work in rotating the ball...but since the ball is being pulled in the inward pull is caused by this centripetal force..so it does work...
First of all, work needs energy. If there was no energy input to the system after the initial given state (which is the case here), then no work can have been done.
Note that the force of the string is not directly towards the centre, it is at an angle to a line between the ball and the centre of the pole. The end of the string attached to the ball does indeed get closer to the centre of the pole, but not because of motion in the direction of the string, only because of motion perpendicular to the direction of the string. Since the ball only moves perpendicular to the force of the string, this force can do no work on the ball.
We started with rotational mechanics not to long ago, and sure enough a similar problem arose in our class, though our teacher simply told us the reason, without letting us work our brains on it.
The thing is, even though the tension in the string is perpendicular, the hinge reaction force by the pole is not, and hence this "non-conservation" of energy, again bringing us to the same conclusion as the rest of the people here, the pole AND the Earth too have to be considered in the system.
Agreed...that is in causing rotational motion the centripetal force does no work...but now we are talking about a tether ball with its radius decreasing because of each rotation...the force which pulls this tether ball inwards is the centripetal force...there is this change in displacement in the direction of the decrease in radius...
The centripetal force in this case work in pulling the ball inwards...and if u want to know how the centripetal force came into existence it would be from the electrostatic attractions..
The thing is, even though the tension in the string is perpendicular, the hinge reaction force by the pole is not, and hence leads to this increase in energy, again bringing us to the same conclusion as the rest of the people here, the pole AND the Earth too have to be considered in the system.
There can be no increase in energy! Consider the whole system: ball, pole, Earth. We are using a frame of reference in which the Earth is stationary. By definition, the Earth has no KE in this frame. Nor does the pole. The ball cannot gain KE, since there is nowhere to gain it from.
When considering the whole system, it's clear that:
1. Angular momentum is conserved. The ball loses angular momentum, the Earth gains the same amount. Since the Earth is so massive, we don't notice its change of momentum.
2. Energy is conserved. The ball loses an immeasurably tiny amount of KE to the Earth. I'm not going to do the calculations: if somebody else wants to they're welcome! For all reasonable limits of accuracy, the ball's KE remains constant. This means that the speed of the ball (not its velocity!) remains constant.
Donald Simanek correctly analyses this problem http://www.lhup.edu/~dsimanek/scenario/insight.htm#skater, using the example of a skater spiralling around a pillar.
I am sorry but the kinetic energy does increase...but the mechanical energy of the net system is conserved..
yes..the calculation is simple...i have posted it above...if u do find any error in those calculations please do tell me..
How is the mechanical net energy conserved if the KE of the ball increases? At the start we have:
KE of Earth: zero
KE of pole: zero
KE of ball: 1/2 m v^2
That's all the mechanical energy we have. The string is massless and inelastic, so it has no KE and no stored energy. There is no energy input to this system, so no way to increase the KE of the ball.
The error is not mathematical, it's an incorrect assumption. In your calculations you make the assumption that the centripetal force does work on the ball. It doesn't, as already explained.
Your calculations would apply correctly to the following case:
Imagine that the string is coming out of a hole at the top of the pole and rotating around this fixed point. Here there is no torque and angular momentum is conserved. As long as the string stays the same length, the ball keeps rotating with the same angular velocity. If the string is pulled through the hole, making the rotating part shorter, the KE of the ball will increase. In this case, work is being done on the system: the work done by the force that is pulling the string through the hole is equal to the increase in KE of the ball.
:-pYes, I did realize that I had written it wrong, which is why I edited it later, a bit too late though.
The two dimensional versions of this problem have been discussed in other threads. Below is a link to one of them that includes images for the string pulled through a hole case and string wraps around a pole case. Short summary: In the hole case, during the time the string is pulled inwards or allowed to move outwards, part of the force is in the direction (path) of the spiraling ball, changing the ball's velocity and kinetic energy. In the pole case, the path is involute of circle, and the tension in the string is always perpendicular to the path of the ball, so it's velocity remains constant.
https://www.physicsforums.com/showthread.php?t=328121
Michael C said:
H
Then what is the force pulling the ball inwards?...voodoo?...:|...there is an obvious decrease in the radius...this displacement according to ur theory is caused by no force?..initially there is no inward velocity...so all of a sudden it moves in?...sounds spooky...So much for Newton's 1st law...!..
Can u explain Why i can't use the same analogy for this problem ?
Also...according to u if angular momentum is conserved..
mVR=mvr...
intially v is the velocity we provide...
at R = r/2
V = 2v
So obviously kinetic energy for the ball 4 times the initial (1/2 m v^2 becomes 4 (1/2 m v^2))...
And there is no torque acting...ofcourse angular momentum conservation hold true..
P.S.. i am sorry if i sound too harsh...I am just in a bad mood...:/
At all times, also initially, there is an inward velocity, because the centre of rotation of the string is not the centre of the pole. The centre of rotation of the string is always at a point on the circumference of the pole, so that the velocity of the end of the string with the ball always has a component towards the centre of the pole.
mVR=mvr...
at R = r/2
V = 2v
once more:
1. Angular momentum of the system Earth + pole + ball is conserved. Ball transfers angular momentum to Earth: ball's angular momentum decreases.
2. Torque is acting since the centre of rotation of the string is not the centre of the pole.
3. KE of the ball cannot increase because there is no energy source external to the system.
Look at the link to http://www.lhup.edu/~dsimanek/scenario/insight.htm#skater that I already posted.
once more:
http://ocw.mit.edu/courses/physics/...of-angular-momentum/MIT8_01SC_quiz25_sols.pdf
check out the problem 5...
Imagine the ball being set into circular motion but let there be two main differences to the original set up.
1.The initial circle can be horizontal or at any angle(including 90 degrees)to the horizontal.
2.The string does not wind itself around the support point so that its effective length remains constant.
When analysing the resulting motion we would take into account,amongst other things, the tension in the string and the weight of the ball.In terms of energy changes we would observe that there are changes between gravitational potential energy and kinetic energy.
It seems that in this thread gravity has been overlooked,but I think that's a mistake. Gravity does not disappear just because the string wraps itself around a post and I don't think that the effects of gravity can be considered as negligible.
Suppose that gravity could truly be considered as negligible,for example let the tethering post and ball be in a region of deep space and with the string taut.The way I see any circular motion now is that both post and ball rotate about a common centre of mass.
I doubt if this will help very much, but at least it's not speculative...
I formed a vector expression for the position of the whirling particle relative to the centre of the post. I then differentiated it wrt time to find the particle velocity. Using these, and the relevant dot and cross products, I found expressions for the KE and angular momentum. Here they are
Ek = [itex]\frac{1}{2}[/itex]ms2[itex]\dot{θ}[/itex]2
L = ms2[itex]\dot{θ}[/itex]
[itex]\theta[/itex] is the angle of take-off of the string from the post (not the angular position of the particle!). s is the length of string still to wind on to the post. [s = b - a[itex]\theta[/itex], in which b is the full string length, and a is the post radius.]
Eliminating [itex]\dot{θ}[/itex] we obtain
L = [itex]\sqrt{2<i>mE</i><sub>k</sub>}[/itex] s
So, if we assume Ek to be constant, as I do, then L diminishes as the 'free' string shortens. I see no problem with the effect being due to the off-axis force from the string, but perhaps I'm being stupid. [And, as AM points out, the Law of conservation of momentum isn't being violated, because the law applies not to the ball and string, but to the Earth, post, ball, string system.]
The result, expressed in terms of s, is independent of the pole diameter.
Dadface said:
Gravity
That's one of the issues with this problem. Depending on the intial conditions, the ball height could increase or decrease over time, which would affect the speed of the ball, exchanging gravitational potential energy and kinetic energy. I'm not sure if there's an initial condition where the ball's center of mass spirals in a horizontal plane as the rope winds around the pole, in which case speed should be constant until impact.
In a simple ball, string and pole set-up the ball will indeed spiral outwards and – under gravity – downwards, and kinetic energy will increase.
For me, though, the problem is more interesting without gravity. We might imagine the unwinding to take place in a freely falling environment, or, less exotically, with the ball moving on a smooth horizontal platform (so the pull of gravity does no work, and is balanced by the normal contact force). While we're about it, I'd like the string very thin compared with the diameter of the pole.
In this way we're back (aren't we?) to the original paradox. [It's certainly the situation which I analysed - post hash 75.]
Philip Wood said:
In a simple ball, string and pole set-up the ball will indeed spiral downwards under gravity, and kinetic energy will increase.
I think that the ball could move upwards or downwards, depending upon the initial impulse.
First imagine the case where the string doesn't change length: one end is at a fixed point. In this case, there is a combination of pendular motion and rotational motion. Starting with the string at a certain angle to the horizontal, it must be possible to give the ball a horizontal impulse so that the weight of the ball is equal to the vertical component of the force on the ball from the string, in which case the ball would rotate indefinitely at a constant speed in a horizontal plane.
Now go back to the original problem. Let's say we start with the string not far from horizontal, and we give the ball an impulse such that it would continue in a horizontal circle if the string didn't change length. As soon as the ball starts moving, the radius of rotation starts decreasing. If the ball's speed stays constant, the tension in the string increases as the radius of rotation decreases, so the angle of the string with the horizontal will decrease: at least initially, the ball rises. I think the ball will end up higher than it started in this case, but I'm not completely sure.
With other initial conditions the ball could certainly move downwards as it moves inwards.
For me, though, the problem is more interesting without gravity. We might imagine the unwinding to take place in a freely falling environment, or, less exotically, with the ball moving on a smooth horizontal platform. While we're about it, I'd like the string very thin compared with the diameter of the pole.
Yes, that's the way the problem has been stated in some other threads, or in http://www.lhup.edu/~dsimanek/scenario/insight.htm#skater: a skater or a puck on ice. In that case your analysis is surely correct. It makes sense: when the ball hits the pole, its angular velocity is zero, since its direction of movement is directly towards the centre of the pole.
I believe this may have been over complicated. I don't know a whole lot about physics (that's why I am here) but put more simply I believe the original question was where does the energy come from that increases kinetic energy and velocity. First, I don't think we can assume that kinetic energy actually increases at any point in this case because (as Mr. Lee pointed out) there is no input of energy after the ball is struck. Rather,as the radius decreases shouldn't the amount of energy required for the ball to make a rotation decrease as well? If my understanding is correct, then with that being said kinetic energy does not increase, but the velocity increases as a result of the decreasing radius. In summary, shorter distance to rotate around pole = less energy required to rotate = higher velocity, and kinetic energy remains the same as it was with initial input. If I am mistaken please correct me as I am here to learn.
Velocity and kinetic energy are related. You cannot increase the ball's velocity without increasing its kinetic energy. (KE = 1/2mv2)
I'm not so good at rotational dynamics - if the pole has a thickness why is angular momentum for the ball not conserved? Please explain carefully?
And btw: Nice thread =)
Do you recall how to calculate the torque (or moment) of a force about an axis? [Force x perpendicular distance from axis to line-of-action of force]?
Now, unbalanced torques acting on things make them change their angular momentum. If this is intuitively ok, then fine. If not, then we'd need to explain exactly what angular momentum means. [Actually, it's defined very much like torque, but with velocity instead of torque.] And then we'd need to do some vector algebra. Let's assume it's intuitive!
We need to choose a fixed axis about which to take the torque. The centre of the pole is an obvious axis to choose. Now. because the string is coming off the side of the pole, it's not pulling the ball straight towards our axis. Indeed, there'd a torque on the ball, according to our definition, of Fa about the axis, if F is the force and a is the pole radius. So therefore the ball's angular momentum keeps changing (decreasing).
hmm okay I think I see it, when I imagine the pole to be very thick. Though I'm not sure, can you draw how the torque vector looks?
Just put it on the figure I attached.
Does this mean that the angular momentum is conserved in the frame of the point of application on the line? And that then means that it is not conserved for the ball?
What is the criteria that angular momentum is conserved for the ball? Must the rotation be around the center of mass for the pole (which its not) and why?
  • Diagram of a vertical cylindrical pole with a thin straight line attached horizontally from its side to a red filled circle representing a ball at the end.
That there are no torques related to the tension in the string. Even if it's not clear how a string applies a torque on a ball following a spiral path (in this case involute of circle), it should be clear that there is a torque applied to the pole by the tension in the string, and applying Newton's 3rd law to torques, torques only exist in equal and opposing pairs, so if there's a torque on the pole due to the string, then there's and equal and opposing torque on the ball due to the string.
Angular momentum is conserved only if you consider the angular momentum of whatever the pole is attached to, usually the earth.
Hallo aaaa202. Does this make sense?
The torque vector (since you ask) is into the page; if you're into vector algebra, torque, G is defined by G = r [itex]\times[/itex]F in which, in this case, r is the displacement vector from O to the ball.
  • Handwritten diagram of a ball on a string wound around a circle centred at O, with the string tangent to the circle and a perpendicular distance a from O, followed by the moment of F about O equals F times a, and handwritten commentary on the torque direction.
Okay thanks! Very helpful! Though one question: Why is it that the rotation MUST be around the center of pole, if the balls angular momentum is to be conserved?
There is rotation about the centre in the case we're considering, isn't there? Angular momentum is not conserved, though. Admittedly it's not a pure rotation,because the ball is also moving radially inwards. But this isn't relevant, either!
When you talk about the ball's angular momentum (that is the angular momentum of a body acted upon by an external force) you have to specify about what point you're calculating that angular momentum. You need a fixed point (certainly not, for example, the point of run-off of the string from the circumference of the pole, because that point keeps moving round the pole, and is therefore accelerating towards the centre).
Exactly the same goes for torque. If you choose the same fixed point about which to calculate torque, G and angular momentum, L, a very simple law applies: G = dL/dt.
Angular momentum is always conserved for the whole system (ball + pole + Earth), no matter which axis is chosen to measure it.
In this case angular momentum is transferred from the ball to the Earth via the pole: there is a torque on the pole, and therefore on the Earth. This means that if we consider only the pole and the ball we come to the conclusion that angular momentum is not conserved: in fact the momentum has been transferred elsewhere.
The ball would have a constant angular momentum if it did not exert a torque on something else. This would be the case if the centre of rotation of the string always stayed at the same point, for instance in the examples where the string is being pulled through a hole.
hmm it's just that when you see the ball for the point of contact between string and pole it makes a uniform circular motion. So can't you say that the angular momentum is conserved in this frame for the ball? And why does that not qualify to the ball's angular momentum being conserved like if the rotation was around the center of mass? :)
Michael C. Agreed. Though, of course, there are interesting cases, such as a system of two charges moving at an angle to each other. [That's not the complete system, I hear someone say.]
aaaa202 As I said, the point of contact of string and pole is accelerating. The laws of Physics need modifying somewhat for use in an accelerating (non-inertial) reference frame. That's why I'm choosing to take our torque and angular momentum about the still centre of the pole.
