Rotational motion and moment of inertia-HELP
The discussion focuses on solving a physics problem involving two masses connected by a thread over a pulley, requiring the calculation of acceleration and tensions in the threads. Participants suggest using a Newtonian approach and emphasize the importance of considering the moment of inertia of the pulley, which is modeled as a homogeneous disk. They clarify that the relationship between linear and angular acceleration is crucial, specifically that linear acceleration equals the radius of the pulley multiplied by angular acceleration. The formulas for the tensions in the threads are confirmed to be correct, and there is a discussion about ensuring proper unit consistency when calculating acceleration. Understanding these concepts is essential for accurately solving the problem.
eyeshiled21
rotational motion and moment of inertia---HELP!
Two masses m1=2.00 kg and m2=1.00 kg are linked by a thread and thrown over a pulley whose mass is 1.00 kg. The radius of the pulley is 0.200 m.
a) Find the acceleration a with which the weights move
b) the tensions T1 and T2 of the threads which the masses are attached to.
Consider the pulley as a homogeneous disk. Disregard friction.
Well, i tried to use the energy method because i know how to do that. But I'm having a problem because the problem doesn't state any given energy. please help me
The energy method won't be very useful here, since they haven't asked for the velocity after the masses change their height.
Try making a free body diagram and work it out by its dynamics.
so you're saying that i must use Newtonian approach to solve this problem? well, I've thought of that at first. But then again, there's this moment of inertia of the pulley, and it's stated there that the pulley is a homogeneous disk. Am i really going to ignore that moment-of-inertia thing? because i think it will be useful
No you don't have to ignore the moment of inertia. Find out the angular acceleration of the pulley, due to the torques by the two tensions. Now how will this angular acceleration be related to the acceleration of the thread?
will you help me using the torque method then? because what the instructor taught us was just up to moment of inertia.
T= F * R sinθ
Where T is torque, F is force, and θ is the angle between the object and the force vector (90 degrees in this case).
And now just like F=ma, T= I * α
Where I is the moment of inertia and α is the angular acceleration.
Now since the thread is not sliding, and the pulley is purely rolling a= R*α (This has an important concept and proof behind it, make sure that you go through it, yourself, or with help of your teacher).
No simply make the free body diagrams of all the 3 objects and use the given formulas.
(And just like in dynamics, acceleration= net force/ total mass, here too, its the same thing, and to account for the pulley's mass, we use I/(R^2), this is just a shortcut, and might not give the correct result always since it has loopholes. In your example, a= (M1g-M2g)/[M1+M2+ Mp/2]. Where Mp/2 is Inertia of pulley upon R^2)
gee, thanks a lot...maybe i will show you my solutions tomorrow...
btw, is that a you give in your reply the linear acceleration or the angular?? because if that's linear, then that will be my answer in a.) right?
and also, is my formula for t1 and t2 correct?
t1=m1g-m1a and t2=m2a+m2g
the α is angular acceleration, and since there is no slipping a(linear acc.) = R*α
Yes that's right.
when i multiply the angular acceleration by the radius of the pulley, my units are m^2/s^2 which for me, looks the wrong unit for acceleration. where did i get wrong?
