How Do You Calculate the Radius of the Sun Using Its Angular Size?
To calculate the radius of the Sun using its angular size, the angle subtended is approximately 0.5 degrees from Earth, located 150 million km away. The equation theta = D/R is used, where D is the diameter and R is the distance from the Sun to Earth. After converting the angle to radians and solving for D, the diameter is found to be about 1,308,997 km. Dividing this by two gives a radius of approximately 654,499 km. The calculations confirm the setup is correct and yield a more accurate result.
needhelp83
The Sun subtends an angle of about 0.5 degrees to us on the Earth, 150 million km away. What is the radius of the Sun?
theta=l/R
(2pi rad/360 degrees)0.5 degrees=2pi(150,000,000 km)
This should be simple, but the answer I get seems to not sound right at all
Have i set this up correctly?
theta=l/R
Why is the title of this thread rotational motion? This is something else. Your equation is correct for finding the diameter of the sun, and you do need to convert to radians as you have done. If I may change the letter for diameter to D, you have
theta = D/R
where R is the distance from the sun to the earth. Solve this for D and try your calculation again. Then remember to find the radius of the sun from D.
theta =D/R
(2pi rad/360°)(0.5°)=D/(150,000,000 km)
D=(1,308,997 km)
R=(1,308,997 km)/2= 654,499 km
Better?
needhelp83 said:
theta =D/R
D=(1,308,997 km)
Better?
Much better
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
