Solving Rotational Motion: Min Force Required for Incline of 30 Degrees
The discussion centers on calculating the minimum force required to roll a 2kg cylinder up a 30-degree incline using a string. The user attempts to break down the problem into components, considering forces acting parallel and perpendicular to the incline. There is confusion regarding the role of rotational motion in the problem, with some participants questioning its necessity. The conversation highlights the challenge of integrating rotational dynamics with linear motion in this scenario. Ultimately, understanding the relationship between tension in the string and the cylinder's rotation is key to solving the problem.
NoBodyKnows
Having a problem figuring this out; it appears extremely easy but I would understand if rotational motion comes into play. I'm just not sure where.
A cylinder of mass 2kg is rolled up an incline by means of a string arranged as shown in the figure. (incline with angle theta and a cylinder being rolled up with a string designating tention) What is the minimum force T required given that the angle of the incline to the horizontal is 30 degrees?
I break it into components (up the ramp and into the ramp are negative) and can say Fx = sin(theta)mg - T = -max
cheers.
If you are pulling the cylinder using a string how can the cylinder rotate?
i knooooooooooooo!
If you know then why do you mention rotation motion? How is the question made any simpler if rotation comes into play? What do you mean "I'm just not sure where." ?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
