MHB Are These Row Equivalent Matrices? Why Am I Getting Different Results?
Pull and Twist
I am having trouble with the following problem;
a.) Find a matrix B in reduced echelon form such that B is row equivalent to the given matrix A.
A=$$\left[\begin{array}{c}1 & 2 & 3 & -1 \\ 3 & 5 & 8 & -2 \\ 1 & 1 & 2 & 0 \end{array}\right]$$
So using my calculator I am able to get,
B=$$\left[\begin{array}{c}1 & 5/8 & 8/3 & -2/3 \\ 0 & 1 & 1 & -1 \\ 0 & 0 & 0 & 0 \end{array}\right]$$
The problem is that the book claims that B should be;
B=$$\left[\begin{array}{c}1 & 2 & 3 & -1 \\ 0 & -1 & -1 & 1 \\ 0 & 0 & 0 & 0 \end{array}\right]$$
Which is weird cause according to the row equivalency theorem, any B of A in REF should be the same unique row equivalent matrix. Why am I not getting the same result?? I am using a TI-83 Plus.
Unfortunately, we cannot verify your calculator input, nor the accuracy of said calculator. Sorry about that.
only RREF is unique, the matrix in your book appears to be properly calculated, but it is NOT in RREF, nor is your matrix $B$ (you have non-zero entries in row 1 above the leading one in row 2, as does the matrix in your book). The RREF can be found here:
Wolfram|Alpha: Computational Knowledge Engine
I verified your book's answer, using the following steps:
a) Subtract 3 times row 1 from row 2
b) Multiply row 2 by -1
c) Subtract row 1 from row 3
d) Add row 2 to row 3
Row-reduction is a path fraught with peril, simple mistakes can ruin everything.
