RPM Limit on Theoretical motor?
The discussion explores the concept of using a gas instead of a solid flywheel to avoid explosion risks while aiming for high rotational speeds. It highlights the challenges of achieving effective energy storage with a gas wheel due to low density and fluid friction, which would reduce energy density and efficiency. Participants discuss the feasibility of using electromagnets to induce a spinning state in the gas, comparing it to cyclotrons and noting limitations related to relativistic effects and particle density. The conversation also touches on practical applications and the mechanics of creating a vortex to enhance gas movement. Overall, the idea remains theoretical, with significant engineering challenges to overcome.
Warpspeed13
Ok so I was trying to design a flywheel for a project of mine and an idea occurred to me. Why not use a gas instead of a solid wheel so you didn't haven't worry about it exploding? Could you spin a conductive gas using electromagnets situated around the gas chamber? Whats the maximum speed at which you could switch the electromagnets with today's technology to maximize the speed?
I would guess the low density and fluid friction would mean it would have terrible energy density and efficiency
What's a gas wheel?
Flywheels store energy by virtue of their rotational inertia. For a flywheel made from a solid circular cylinder, the mass moment of inertia I = mr2, and the amount of energy stored when the angular velocity of the flywheel is ω rad/sec is:
E = Iω2 = mω2r2
By making a 'wheel' out of gas, the mass m will be much smaller than if the wheel is made of metal, and the amount of energy which can be stored for a given angular velocity will be proportionately reduced.
I'm ok with low energy density I'm more interested in creating something that would spin the gas at very high rpm. Not so much for a useful purpose but as something interesting to do.
Ok a more accurate description would be to induce a state in the gas in which the majority of the gas particles have an orbital trajectory about a single axis.
This depends on size and construction of machine. Out of curiosity, I've done some short high speed test runs on small induction machines (Pn< 3 kW) up to 10 000 rpm. They all survived . Big machines (Pn>1 MW) would probably selfdestruct much more before that.
You mean like The Sun?
I don't see how you would get the force right for neutral particles. You can collect a cloud of ions, of course, like a small cyclotron. They can reach relativistic speeds, but the density is extremely low (and you get synchrotron radiation) - not practical as energy storage.
Hadn't thought of that comparison but you basically.
Ok cool. So the limit is constrained by how effectively you can bend the trajectory of the ions around the track.
Cyclotrons are limited by relativistic effects and at some point the size becomes impractical. Even higher energies can be reached with other accelerator types. That has nothing to do with flywheels any more, however.
That's just a definition of the word "spin". I'm asking physically how you hope/plan to do it. I'm unable to envision the concept.
Think like a cd or a galaxy or the event horizon on a black hole. I want to use electromagnets to create a similar state in a body of gas. Since the gas if ionized will be attracted to the negative pole on an electromagnet I want to use electromagnets in a circle to rotate the body of gas around the center of a container at high speed.
That's fine i,m not looking to accelerate anything to close to light speed. Id prefer to get a larger amount of gas ionized or not,moving at a couple hundred m/s
When I was a kid, I would drive past industries that generated a lot of dust, and I'd regularly see cone-shaped air cleaners. They used to capture my imagination.
http://en.wikipedia.org/wiki/Cyclonic_separation
These were constructed from galvanized steel and would be about 6-8 feet in diameter. It was a good use of spinning air as it captured a massive amount of pollution.
Your thoughts remind me of how I found out about MHD generators,...they were around a few years before I imagined one in my mind.
I was thinking about alternators and how spin speed and heat would bring them to a state of shrapnel, the idea that came sounds similar to what you are describing.
Things you might consider...
The mechanics of a vortex tube cooler (spin speed of the air)
An alternator with all components ground to a fine powder
A sandstorm with silicon particles in suspension
Mix a quantity of iron and copper powder in the vortex flow, guided through a magnetic field.
Feeding particles in a layering pattern where they produce an electrical current, then draw from that, would be the goal to reach.
Spin speed and heat becomes almost irrelevant. Participial mass and speed determine voltage and current, recycle of the powders should be easy enough.
An alternator of sorts that has a very high wear factor, but super cheap to replace :approve:
Perhaps there is something in that dribble that coincides with your thoughts, or maybe will trigger in your mind a thought that makes your vision click. :)
A couple of hundred meters per second is possible with conventional solid flywheels.
You can't get a large collection of ions. Every ion has at least one elementary charge, if you have too many they repel each other too much.
