What Happens When You Bombard a Rubber Ball with Electrons?
Bombarding a rubber ball with electrons can induce a negative surface charge as some electrons may remain on the ball. Under certain conditions, this process could also lead to the emission of electromagnetic radiation, although significant radiation would likely result in damaging the rubber. In contrast, using a steel ball could produce notable x-rays from the bombardment. It is recommended to conduct such experiments in a vacuum to avoid interference. Overall, the discussion highlights the potential effects of electron bombardment on different materials.
PhysicsInNJ
A friend of mine posed a question; if you take a rubber ball and bombard it with electrons, what would happen?
I posited that some of the electrons would likely stay on the surface of the ball, giving it a negative charge. I then suggested that if under the "right" conditions you may be able to have photons or some other kind of electromagnetic radiation emitted.
Am I totally off or was there some truth to what I was saying?
You could certainly induce a negative surface charge.
The EM is also true, if only because "some kind of EM radiation" covers such a wide range.
By the time you got "real" EM out of the thing, you would be destroying the rubber.
... now switch to a steel ball and you can get some significant x-rays.
BTW: You should do these experiments in a vacuum.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
