Rubber ball Rotational Motion Question
A rubber ball with a radius of 3.2 cm rolls off a table, falling 0.66 m while completing 0.37 revolutions. The discussion revolves around calculating the ball's initial linear speed using energy conservation and rotational motion principles. The derived equations indicate that the initial speed leads to an imaginary number, prompting questions about the approach and potential energy considerations. Ultimately, the poster realizes that the ball's angular velocity remains constant as it leaves the table, allowing for a straightforward calculation of the initial speed using the relationship between linear and angular velocity. The final linear speed is determined to be 0.20 m/s.
Theta
Note: I refrained from using any of the latex references, so bear with me.
A rubber ball with a radius of 3.2 cm rolls along the horizontal surface of a table with a constant linear speed v. When the ball rolls off the edge of the table, it falls 0.66 m to the floor below. If the ball completes 0.37 revolutions during its fall, what was its linear speed, v?
a) Variables extracted from the question
r = 3.2 cm = 0.032 m
h = 0.66 m
theta = (2pi)(0.37 revolutions) = (2pi x 0.37) rad
2. Homework Equations and physics principles/concepts
a) Equations
i. d = Vit + 0.5at2
ii. v = rw
b) Physics principles/concepts
i. Law of conservation of energy (?)
ii. Rotational kinetic energy and the moment of inertia (?)
iii. Kinematics (?)
a) Energy is conserved, therefore:
Ki + Ui = Kf + Uf
b) There is no potential energy as the bottom of the table. Furthermore, we are analyzing the rotational motion of a rubber ball (ie. I = 0.4mr2). Therefore:
Ki + Ui = Kf
0.5mvi2 + 0.5(0.4mr2)(vi/r)2 = mgh + 0.5mvf2 + 0.5(0.4mr2)(vf/r)2
c) We can clean up the equation by eliminating the mass and radii parameters, and multiplying each term by 2.
vi2 + 0.4vi2 = 2gh + vf2 + 0.4vf2
d) Like terms can be collected and vi can be solved for.
vi = sqrt ((5/7)[(7/5)vf2 - 2gh])
e) We only need the final linear speed now. To determine that, we can use:
vf = rwf
i. As can be seen above, we need to determine wf. To do this, regular kinematics can be applied to find the total time the ball spends in the air.
d = Vit + 0.5at2
d = 0.5at2
t = sqrt (2d/a)
t = sqrt [(2 x 0.66 m) / (9.81 m/s2)]
t = 0.37 s
ii. At the very beginning, the amount of revolutions (in radians) was determined. By dividing the revolutions by the time obtained above, we can obtain wf, and ultimately vf.
vf = rwf
vf = (0.032 m)[(2pi x 0.37) / (0.37 s)]
vf = 0.20 m/s
f) Finally, we can solve for initial linear speed.
vi = sqrt ((5/7)[(7/5)(0.20 m/s)2 - 2(9.81 m/s2)(0.66 m)])
vi = WHAT??!? AN IMAGINARY NUMBER?
So yeah, I do not know what I am doing wrong. Am I misinterpreting the question? Am I approaching the question in the wrong way? Does my logic make any sense?
as the ball falls down, its rotational speed does not increase :)
can u imagine why?
and also, in the energy equation where should we put the potential energy, does the system lose or gain potential energy?
hope that helps :)
vf = rwf
vf = 0.20 m/s
Since ω does not change, the ball has this same ω when it leaves the table. Can you use that information to find vi=rω?
Oh, wow, I think I figured it out.
Thanks for the help you two.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
