Safe Discharge of Monitor Capacitors: What's the Best Method?
  • Thread starter Thread starter D_Dean
    Discharge
Discharging monitor capacitors safely is crucial due to the high voltages they can hold, with external caps potentially retaining several hundred volts. Using a screwdriver for discharge is risky; a 1kOhm power resistor is recommended to limit current and ensure safer discharge times. It's important to verify the capacitance values, as larger electrolytic capacitors can be in the range of several hundred microfarads, which requires different handling. For smaller capacitors (up to 0.01uF), black ESD foam can be an effective discharge method due to its high resistance. Proper methods and tools are essential for safe disassembly of old monitors.
D_Dean
My buddy works at an extremely small (4 guys and a room) computer parts recycling and disposal place. They want to be able to take apart old monitors but are afraid of the potential shock from the main caps. I am told that the voltage can get up to 25,000 volts (I'm not sure of this value) and the capacitance is between .005uF and .01uF. They just use a screwdriver to discharge the voltage, which sounds not too smart.
Does anyone know a good resistor (power / ohm value) to use for something like this. Does anyone have any other good ideas?
Thanks.
Derek
The 25kV is left on the tube itself, not on external caps. The external caps might have a few 100V on them, though, so they are still dangerous. I'd think that using a 1kOhm power resistor would limit the current and give reasonable discharge times. I'd check those capacitance values that you list -- the larger electrolytic caps will be many uF, often several 100uF.
If the caps really are just 0.01uF max, you could probably just use black ESD foam to discharge them. ESD foam is several 100kOhms per square, so you can calculate whether the discharge time constant would be practical for them.
Thanks
I'll check it out and get back to you if I have any more problems or questions.
Thanks,
Derek
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
