Sampling above the Nyquist rate but
  • Thread starter Thread starter brendan_foo
    Rate Sampling
Sampling just above the Nyquist rate theoretically allows for perfect interpolation of a continuous-time signal using the sinc function, provided the signal is sufficiently sampled. However, practical limitations arise in real-time DSP systems due to the finite speed of processing, which prevents the summation of an infinite number of terms in the sinc function. Truncating the sinc function can lead to issues, and different windowing techniques may be employed to improve results. The discussion also highlights the importance of considering practical sampling rates above the Nyquist frequency to avoid potential issues in real-world applications. Overall, the conversation emphasizes the balance between theory and practical implementation in digital signal processing.
brendan_foo
http://s188.photobucket.com/albums/z65/liznbren/stuff/?action=view&current=envelope.jpg"
If I sample at just fractionally above the Nyquist rate, and I obtain a sequence as is shown in the linked image, is it reasonable to expect perfect interpolation (say with a Sinc function ideally) as it is taken over infinite time.
I am using a real-time DSP chip and I get a modulated output, as as evident in the image linked.
Any comments on this sort of sequence would be great. It has a discrete frequency of about 0.9 pi.
Thanks...
Brendan
the answer is: theoretically yes. that sinusoid shown in your referred figure is (barely) sufficiently sampled. any time a continuous-time signal is sufficiently sampled (that is sampled at a rate that exceeds twice the highest frequency component of the signal), the original continuous-time signal can be reconstructed from the samples by use of the sinc( ) function as
x(t) = \sum_{n=-\infty}^{+\infty} x[n] \ \mathrm{sinc}\left( \frac{t-nT}{T} \right)
where
\mathrm{sinc}(u) \equiv \frac{\sin(\pi u)}{\pi u}
and
F_s = \frac{1}{T} is your sampling frequency.
now the problem you have with your real-time DSP chip is that no matter how fast it is (yet finite in speed), you can't add up an infinite number of terms. so your sinc() function will get truncated somehow. simply cutting it off is applying the rectangular window which is pretty bad, so you will likely use a different window to make the reach of your sinc() function finite. in audio, i have been pretty much satisified with a reach of +/- 16 samples from the interpolated point that you're calculating. but i know there are sample rate conversion chips that have a reach of +/- 32 samples (a summation of 64 terms).
this is a good forum and i wouldn't mind seeing more DSP discussion here, but the real action is at the comp.dsp USENET group. that's where i would take it.
Thanks! I guessed this was so, I tried using MATLAB to create such a convolution of sinc( ) functions and as the length got arbitrarily large the results were convergent to the theory.
The practicalities of actual implemented DSP are very interesting indeed it seems.
All of this is for Direct-Digital-Synthesis by means of a wave-lookup table. It serves me well to look at it as the dual of sampling an actual sinusoid and proceeding by such means.
Thanks for the reference to the USENET group!
-Brendan
Hello!
May be about sampling sine and cosine signals will help the papers below:
ET 4 CO 198.pmd
www.ieindia.org/pdf/88/88ET104.pdf[/URL]
9 CP PE 8.pmd
[PLAIN]www.ieindia.org/pdf/89/89CP109.pdf[/URL]
Best regards
P Petrov
Petre said:
Hello!
ET 4 CO 198.pmd
9 CP PE 8.pmd
Best regards
P Petrov[/QUOTE]
At first I was worried that this post was spam, but after skimming the first paper, it seems perfectly appropriate for this thread. Thanks, Petre, and welcome to the PF.
Quiz Question for brendan -- What practical reason comes into play that would drive you in a practical system to not sample just barely above the Nyquist frequency? Very important consideration...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
