Solve Satellite Problem: Speed & Orbit Time
  • Thread starter africanmasks
In summary, the astronaut in Figure P4.32 is preparing to dock with a Westar VI satellite in a circular orbit 600 km above the Earth's surface. Using the given information and equations for centripetal acceleration and velocity, the speed of the satellite is calculated to be 2215.401 m/s. To determine the time interval required for one orbit around the Earth, the formula for velocity is rearranged, resulting in a time of 2.45 x 10^4 seconds.
africanmasks
The astronaut orbiting the Earth in Figure P4.32 is preparing to dock with a Westar VI satellite. The satellite is in a circular orbit 600 km above the Earth's surface, where the free-fall acceleration is 8.18 m/s2. Take the radius of the Earth as 6400 km.
a.) Determine the speed of the satellite.
b.) Determine the time interval required to complete one orbit around the Earth.
centripetal(radial) acceleration= v^(2) / r
v= 2(pi)r/ T
8.18 m/s^(2) * 600,000m= v^(2)
v= 2215.401 m/s
Is that right?
For b) I am assuming that you mean for the satellite to complete one orbit around the Earth?2(pi)*6400,000m/2215.401 m/s= TT= 2.45x 10^(4) s
Yes, your solution for the speed of the satellite is correct. To determine the time interval required for one orbit, you can use the formula v = 2πr/T, where v is the speed of the satellite, r is the radius of the orbit, and T is the time interval. Rearranging the formula to solve for T, we get T = 2πr/v. Plugging in the values, we get T = 2π(6400 km + 600 km) / 2215.401 m/s = 5569.8 seconds. Therefore, it takes approximately 5569.8 seconds or 92.83 minutes for the satellite to complete one orbit around the Earth.
1. How do you calculate the speed of a satellite in orbit?
The speed of a satellite in orbit can be calculated using the formula v = sqrt(GM/r), where v is the speed in meters per second, G is the gravitational constant, M is the mass of the planet being orbited, and r is the distance between the satellite and the center of the planet.
2. What factors affect the speed of a satellite in orbit?
The speed of a satellite in orbit is affected by the mass of the planet being orbited, the distance between the satellite and the planet, and the gravitational constant. Other factors such as atmospheric drag and solar radiation can also have an impact.
3. How is the orbital period of a satellite determined?
The orbital period of a satellite is determined by the formula T = 2π*sqrt(r^3/GM), where T is the period in seconds, r is the distance between the satellite and the center of the planet, and G and M are the gravitational constant and mass of the planet, respectively.
4. Can a satellite's orbit time be changed?
Yes, a satellite's orbit time can be changed by altering its speed or distance from the planet. This can be achieved through the use of thrusters or gravitational assists from other bodies in space.
5. What is the relationship between a satellite's speed and its orbit time?
The speed of a satellite and its orbit time are inversely proportional. This means that as the speed of the satellite increases, its orbit time decreases, and vice versa. However, this relationship is affected by other factors such as the mass of the planet and the altitude of the satellite's orbit.
