Satellite relay system and transmission losses
The discussion revolves around confusion regarding the calculation of amplifier gain (g_amp) in a satellite relay system, particularly when input power and uplink frequency values differ from those in the example provided. The user questions why g_amp is calculated as 162 dBW when it seems logical to subtract transmission losses instead. It is clarified that g_amp is variable and adjusted to achieve a specific output power level, which can lead to apparent discrepancies in calculations. Additionally, there is uncertainty about a multiplication factor of 6 in a solution found on Chegg.com, with suggestions that it may relate to specific antenna efficiency. Overall, the conversation highlights the complexities of calculating transmission losses and amplifier gain in satellite communications.
Adir_Sh
Hello.
Below I have a problem I can't quite understand to the full:
http://www.israup.net/images/027d25c3acde86a09bcb9e1ed869560a.png
http://www.israup.net/images/6757f5c30cbcfe051295b1b1e4614489.png
And that is the suggested solution:
http://www.israup.net/images/955a5be90466defb399d78c7693c8e2f.png
Now my question is about that g_{amp} calculation in the solution provided in the solution manual for the book I'm solving from.
If P_{in}=35 dBW and not 30 dBW as it is in the example, and also uplink frequency value changes from the example provided to the question, then how g_{amp}=18+144=162 dBW? Shouldn't it be g_{amp}=18-103=-85 dBW? -103dBW should reasonably be substracted (and not like 144 being added) since it stands for transmission loss, isn't it?
But the in Psat (out) it seems like they do compensate for it because they do add 162dB...
I have a strong feeling that I miss something here in the idea behind g_{amp}. Could it gain the whole uplink loss in some way? I'm quite curious about that really... :rolleyes:
Thanks.
The big typo in example 3.3-1 is the statement: 35dBW + 55dB - 199.1dB + 20 dB = -144.1dBW.
The result should be -89.1dBW.
The idea behind gamp is that it is variable (within some practical limits) and is whatever it needs to be to produce 18dBW (input to the downlink transmitter antenna).
Likes 1 person
Another question, same subject
Well, first of all thanks for your quick response lewando :approve:
I have another little question:
I found this solution on Chegg.com:
http://www.israup.net/images/06364d1120e02d09bb453073c3d4fb12.png
Everything is clear to me, apart from that multiplication in 6 when calculating the maximum antenna gain. Why 6?
Do you suggest there's probably a mistake? Or maybe I misinterpret once more? :shy:
Thanks.
I don't know where that 6 came from. One possibility is that the chegg equation is for a specific antenna. Your working assumption that Ae (the effective aperature) = area is based on unity efficiency of the "antenna area". Perhaps the chegg antenna had less than unity efficiency.
Likes 1 person
