Satellite velocity and momentum
The discussion revolves around a satellite in a circular orbit around the Earth, which experiences an explosion that divides it into two pieces of differing masses. Participants are exploring the implications of this explosion on the velocities and orbits of the resulting fragments.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of the satellite's initial speed using gravitational potential energy and kinetic energy equations. There is uncertainty regarding the application of linear momentum to find the velocity of the larger piece after the explosion. Questions arise about the assumptions made regarding momentum and energy conservation in the context of the explosion.
Some participants have provided guidance on maintaining the expressions in terms of variables rather than numerical values. There is an ongoing exploration of energy conservation principles before and after the explosion, with participants questioning how to relate the energies of the system at different states.
Participants are navigating the complexities of momentum and energy conservation in a multi-body system, with specific attention to the definitions and assumptions involved in the problem setup.
jlayla99
A satellite moves around the Earth in a circular orbit of radius r.
a) What is the speed vo of the satellite?
Suddenly an explosion breaks the satellite into two pieces, with masses m and 4m. Immediately after the explosion the smaller piece of mass m is stationary with respect to the Earth and falls directly toward the Earth.
b)What is the speed vi of the larger piece immediately after the explosion?
c) Because of the increase in its speed this larger piece now moves in a new elliptical orbit. Find its distance away from the center of the Earth when it reaches the other end of the ellipse.
K=.5mv^2
E=-GMm/2r
mv=mv
E=-GMm/2a
a) I think I got the answer to a:
.5mv^2=GMm/2r
v=sqrt(GM/r)
Then substituting in the values of G and M (Mass of the Earth):
v=1.99x10^7/sqrt(r)
b) I am having trouble with this because I don't know if I can simply use linear momentum. If so then I can just assume that the smaller mass has no momentum in relation to the first.
mv=mv
5m(vo)=4m(vi)
(5/4)vo=vi
Is it really that simple?
c) I'm kind of shooting in the dark with this one, but can I assume that the energy initially (GM(5m)/2r) is going to equal the second energy (GM(4m)/2a?
.5mv^2=GMm/2r
v=sqrt(GM/r)
v=1.99x10^7/sqrt(r)
OK, but I wouldn't bother plugging in numerical values. Leave your answer in terms of G, M, and r.
mv=mv
5m(vo)=4m(vi)
(5/4)vo=vi
Yes, that simple.
Compare the energy of the masses before and after the explosion.
what do you mean compare the energies?
the energy before: .5m(vo)^2 - GM(5m)/2r
the energy after: .5m(vi)^2 - GM(4m)/2a
where do i go from there?
Express the total energy immediately after the explosion in terms of the energy before the collision. Then use that new energy to solve for length of the new orbit.
  • · Replies 39 ·
  • · Replies 16 ·
