Discovering the Mystery of Satellite Shadows: A Beginner's Guide
  • Thread starter Thread starter learningisfun
    Sattelite
It is not possible to see the shadow of an artificial satellite from the ground due to the size and distance involved. The sun's angular diameter creates a shadow cone with an angle of about 0.5 degrees. For a satellite like the Hubble, which is approximately 2-3 meters across, the shadow cone extends about 500 meters long. Therefore, one would need to be within 500 meters of the satellite in orbit to observe its shadow. This highlights the significant scale differences between satellites and the sun.
learningisfun
Another noob qeustion that I do not have the knowledge to figure out.
It's is possible to see the shadow of a sattilte?
Astronomy news on Phys.org
You mean an artificial satellite, rather than the moon (in astronomy moons are properly called satellites)
The sun has an angular diameter of around 0.5 degree so the shadow will form a cone with an angle of 0.5 deg.
Say a satellite is 2-3m across (eg Hubble) then the cone will be 500m long (easy to see if you draw a sketch)
So unless you are in orbit less than 500m from the satellite - no you won't see a shadow
oh , that's amazing, the sun is far larger,
*draws out sketch* troginnometry ^.^
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
