Saturable Reactors: Power Control with Permanent Magnets
  • Thread starter Thread starter Jdo300
Saturable reactors, or magnetic amplifiers, control AC power by varying the saturation of the core around which the AC coil is wrapped. The discussion highlights that while saturation can increase power transfer in certain configurations, it also reduces energy transfer in transformers by diminishing the flux linking to the secondary coil. When a non-magnetic core is used with an AC coil and exposed to a permanent magnet, the expected behavior is a decrease in efficiency, similar to holding a magnet up to a transformer, which disrupts its operation. The B-H curve illustrates that as saturation occurs, the relationship between magnetic flux density and magnetizing force becomes non-linear, leading to reduced energy transfer. Overall, the effectiveness of magnetic amplifiers depends significantly on the core material and its saturation level.
Jdo300
Hello,
I've been doing some research into antiquated Magnetic amplifiers. From what I understand, one can use a mag amp to control the power of an AC field by varying the saturation level of whatever core the AC coil is wrapped around (basically). I know that this can be accomplished by using a type of transformer where the control coil is pulsed with DC at varying levels to control the AC coil.
My question is that if it is the magnetic field that controls the power level of the AC signal, and the more saturated the core, the more power can get through. What would that same AC coil do if you wrapped it on a non magnetic core and exposed it to a magnetic field from a permanent magnet placed in close proximity to the coil?
I'm not familiar with mag amps per se, but when you saturate the core of a transformer, you reduce the transfer of energy from primary to secondary, not increase it. Look at the B-H curve for magnetic material...As you get into saturation, the B does not increase in proportion to H anymore. It increases more slowly. That will reduce the flux linking to the secondary coil, compared to what you would get if the material were not saturating.
If you hold a magnet up to a transformer, the transformer does not work well at all.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
