How Do You Apply Schmidt Orthogonalization to Four 4D Vectors?
  • Thread starter Thread starter haras
To apply Schmidt Orthogonalization to the four 4D vectors (1,1,-1,-1), (1,1,0,0), (1,2,3,1), and (0,1,0,1), start by setting u1 equal to the first vector. For each subsequent vector, subtract the projections of all previously computed u vectors from the current vector to obtain the next u vector. The projection is calculated using the formula proj(u_i)v_j = (dot(v_j, u_i) / dot(u_i, u_i)) * u_i. Normalize each u vector after computing it to ensure they are orthogonal and unit vectors. This process continues until all vectors have been processed, resulting in an orthogonal set.
haras
Hello,
I must use this schmidt method to form an orthogonal set from the 4 column vectors: (1,1,-1,-1), (1,1,0,0,), (1,2,3,1), (0,1,0,1).
the only examples i can find are for 2 2space vectors, and that has the eqns.:
u1=v1
u2 = v2 - proj(u1) v2
i'm confused about how to expand that to 4 vectors in 4space, and also i think, about how to do projections.
THANKS!
Do it step by step. After you have u1 and u2 do
u3=v3-proj(u1)v3-proj(u2)v3, and so on.
You should normallize the u's at each step.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
