Schrodinger eqn. and its relativistic generalisations
masudr
I've suddenly run into a problem. This has probably arisen from the fact that I've yet to have (and may never have) formal teaching on the relativistic generalisation of QM.
I see the Schrodinger equation proper as
\hat{H}| \psi (t) \rangle = i\hbar \frac{d}{dt} | \psi (t) \rangle
Is this valid in the relativistic case? I guess it must be because wherever I have seen relativistic generalisations, they tend to be relativistic generalisations of the Hamiltonian of the single particle classical Hamiltonian p^2/2m. And as it happens we can recast the above equation into some covariant form (is this coincedence or is it meant to happen?)
But then I later realized that the Dirac equation is more the equation of motion for the spinor field, i.e. in QED, we use the Dirac (for electron spinor field) + EM (for photon field) + interaction (electron-photon) Lagrangian.
In any of this, is the Schrodinger equation proper ever replaced by something else? Or is all we do is find Hamiltonians that describe our relevant particles? And does this apply to particles, or the associated field, or both?
Thanks in advance.
Ys, it is.
Of course it's not a coincidence, if the eqn is Lorentz invariant, then the Lorentz scalars must be made visible, i.e. using Lorentz space-time indices.
Do you miss a "than" btw "more" and "the equation" ? If so, then you're wrong. The (IN)HOMOGENOUS Dirac eqn always describes the dynamics of the quantized Dirac field.
masudr said:
In any of this, is the Schrodinger equation proper ever replaced by something else? [/QUOTE
Well, in QFT, the SE properly describes the time evolution of state vectors, just like in the Galilei-invariant QM. So if you're worried about time-evolution of quantum (multi/uni)particle states, then you'd be worring about the equation posted by you.
Canonical quantization, even for free quantum field theories, is a mathematically complicated problem. It should be rigorously done using axiomatic field theory, either the Wightman formulation, or the Haag-Araki one. I'd say the path-integral approach to QFT is the least troublesome method, that is of course if you don't really inquire what a path-integral is from the mathematician's point de vue.
Daniel.
In my opinion, this is one of the most important not yet satisfactorily solved questions in physics. For more details see
http://arxiv.org/abs/quant-ph/0609163
especially Secs. VII-IX.
The cited paper's author doesn't get it. He's attacking a strawman. Anyone who's practiced QM knows full well that the idea of wave-particle duality is a useful metaphor, nothing less, nothing more. It, I think, makes the notion of and direct evidence for electron diffraction easier for many to grasp -- knowing of course that such a description is ultimately a fiction. This is worth a big deal of concern? (One of my QM professors, J.H. VanVleck, used to describe a beam of electrons as a flight of mosquitoes. Should he give up his Nobel Prize for being so simple minded as to equate inanimate objects with animate opjects? And, as I recall, he didn't even warn us that he was using figurative language.)
Regards,
Reilly Atkinson
Regards,
Reilly Atkinson
out of curiosity, did you read the paper? i thought it was interesting, if somewhat uninhibited.
your professor probably didn't want to confuse you.
Yes, I read the paper. Or, more correctly, I read more than half, but decided that reading more was not of interest to me. And, I do believe that is my right, without any explanation. (As a jazz musician, I say, man, that's a bunch of jive, ain't makin' the changes.)
My professor was prone to jokes, used wonderful figurative language, and, rightfully so, assumed his student were sufficiently bright and sophisticated in the use of mathematics and of language to understand and benefit from his deviations from the straight and narrow. Generally speaking, most of us, even non-physicists can tell figurative language from straight and pragmatic expression. He was not in the slightest interested in any behavior that might demean his students.
Your last comment says a lot more about you, than about me or Prof. VanVleck.
Reilly Atkinson
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
