Screw Pump Sizing: Calculations for Inverted Pumps
Calculations for sizing an inverted screw pump can be derived from standard screw pump equations, regardless of whether the screw or casing is rotating. The user is seeking formulas to determine the diameter, fin height, spiral pattern, and speed for moving 150 to 400 lbs of dry powder per minute. Recommendations include exploring Polymer Processing literature, particularly works by Bernhardt, Tadmor, and Osswald, which discuss screw pumps in the context of extrusion. Understanding the rheological behavior of the granular material and the kinetic friction on the granular bed is essential for effective design. Further research in the area of Deformational Behavior of Granular Materials may also provide valuable insights.
hmvyoral
Does anyone know where i can get the calculations for sizing an inverted screw pump. Inverted being that there is no screw but the fins art attached to the inside of a pipe and the pipe is rotating. I am moving any where from 150 to 400 lbs of dry powder per minute, depending on the amount of powder being produced. I don't have the exact length yet, hence why i just need the formulas. The idea is to find the diameter, fin height, spiral patern, and speed. If anyone knows where i can get the calculations i would apreciate the help.
Use the equations for a regular screw pump. It doesn't matter whether the screw is rotating and the casing is stationary or the casing is rotating and the screw is stationary.
I would like to use the equations for a screw pump, but i am unable to find any online. I had figured that everything would be the same because all i did was eliminiate the screw shaft and put the fins on the wall of the casing. If you know where i can get some calculations i would apreiciated it.
Try looking in the Polymer Processing literature in the area of extrusion. They use screw pumps (extruders) to compact and melt granular and powdery solids as part of producing a polymer melt. Look under the names of Bernhardt, Tadmor, Tadmor and Klein, and Osswald. In order to design a screw pump for a granular material, you need to have some idea of the rheological behavior of the granular material on a scale somewhat larger than the particle size. I'm not sure how much work has been done in this area, since I haven't followed it. But consider looking under the subject of Deformational Behavior of Granular Materials. In a screw pump, kinetic friction on the granular bed is also important. I hope this is helpful.
Thank you, I will start looking into that. I will let you know if i find anything.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
