What is the equality of first and second focal lengths in Sears' Optics?
Sears' Optics claims that the first and second focal lengths are equal, but this assertion lacks proof, raising concerns among readers. The first focal length is defined as the distance from the first focal point to the first principal point, while the second focal length follows a similar definition. It is noted that these lengths are generally not equal unless the lens is symmetrical, which Sears does not clarify in his examples. A deeper understanding of the principle points is necessary to reconcile Sears' claims with established optical principles. Ultimately, the discussion emphasizes the need for clarity and proof regarding the equality of focal lengths in optical systems.
ttzhou
In Sears' Optics, chapter 4, Sears claims that the first and second focal lengths (distance from first and second focal points to the first and second principal points, respectively) are equal, and he seems to imply that this is true in general, without proof.
I am a mathematician at heart, and the lack of proof of this bothers me immensely. Would any PF'ers be able to shed some light on this matter? It would be greatly appreciated. I did a forum search and went through about 4-5 pages and found nothing similar.
Basically, f = f' where f stands for the first focal length and f' stands for the second.
I tried imagining this using Fermat's principle of reversibility, but it seems kind of sketchy...
What are they calling the "first" and "second" focal lengths?
In general, the front and back focal lengths will be different.
The two are the same if the lens is symmetrical.
See: http://en.wikipedia.org/wiki/Focal_length
Hi Simon,
As mentioned in my post - the first focal length is defined as the distance from the first (or front) focal point to the first principal point, which is defined as the intersection of the first principle plane and the axis. The second focal length is defined analagously.
I've already read the Wiki article and I did not find it to be of use. My intuition tells me that in general they are not equal, but according to Sears, he constantly makes reference to them being equal, and nowhere has he stated that the lenses are symmetrical. In fact, he does an example in which the lens is asymmetrical, but STILL claims the focal lengths are equal.
OK - I was trying to guide you there , let's try another approach: reading FFL and BFL - under "general optical systems" in wikipedia, there is a detailed derivation showing that these two lengths are not, in general, the same.
Comparing wiki with Sears, however, FFL (eg) is defined from the first optical surface. FL1, by Sears, is defined from the first principle point ... which refines the search: to understand Sears, you need to understand how the principle point is found [pdf]. FL1=|F-P| and FL2=|F'-P'|. Wikipedia calls this "EFL" and, indeed, FL1=FL2.
From there is it a matter of geometry.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
