Second-Order Differential Equation
5 replies · 2K views
Char. Limit
Prove that for the differential equation [tex]m x''(t) = -k x(t)[/tex], one solution is [tex]x=A cos(\omega t)[/tex], where [tex]\omega = \sqrt{\frac{k}{m}}[/tex].
[tex]x^2+1 = (x+i)(x-i)[/tex]
Well, I haven't taken differential equations yet, but I understand that you have to turn this differential equation into a polynomial somehow. Then, the roots of that polynomial give you the solution. I need the details, though...
Since you're given a solution, you can prove it satisfies the equation simply by plugging it in.
More generally, for a homogeneous differential equation with constant coefficients, you can assume a solution of the form y=erx. Plug that into the differential equation and see what you get.
Hmm... all right, let's assume that's the case...
if x=A e^(rt), then x'' = r^2 A e^(rt), and so...
m r^2 A e^(rt) = - k A e^(rt)
Divide both sides by A e^(rt), because that's never zero...
m r^2 + k = 0
Divide both sides by k...
[tex]\frac{m}{k} r^2 + 1 = 0[/tex]
[tex]\left(\sqrt{\frac{m}{k}} r\right)^2 + 1 = 0[/tex]
[tex]\left(\sqrt{\frac{m}{k}} r + i\right) = 0, r = -\sqrt{\frac{k}{m}} i = -\omega i[/tex]
[tex]\left(\sqrt{\frac{m}{k}} r - i\right) = 0, r = \sqrt{\frac{k}{m}} i = \omega i[/tex]
So, we get...
[tex]x(t) = A ( e^{\omega i t} + e^{-\omega i t}) = A cos(\omega t)[/tex]
Is that right?
Because our physics teacher challenged us to do it the hard way.
Yes, that's right. Any linear combination of the two solutions you found, eiωx and e-iωx, in particular cos ωx, will also be a solution.
