Undergrad What are the patterns and formations seen in selected area diffraction?
  • Thread starter Thread starter Milchy
    Area Diffraction
Selected area diffraction in transmission electron microscopy (TEM) produces patterns that reveal information about the crystal structure of materials. The dots in the diffraction pattern correspond to specific lattice planes, while the rings indicate the presence of polycrystalline samples, similar to the Debye-Scherrer method used in X-ray diffraction. Constructive interference occurs at certain angles, leading to these distinct features in the pattern. Understanding the relationship between the diffraction pattern and the crystal lattice can be visualized through unit cells and the interaction of electrons with the crystal structure. This method allows for the determination of lattice spacing and Miller indices, essential for characterizing materials.
Milchy
Can anyone explain me the pattern that is obtained from selected area diffraction? What does it show? What are the dots? What are the rings? (example: http://www.microscopy.cz/html/images/2605_1_d0f65ce7_fig2.png)
I know that during X-ray powder diffraction, radiation is shined at the powder at varying incident angles. At certain theta angles the radiation diffracts from different lattices in the powder to form constructive interference, which shows up as peaks in the diffractogram. From the peaks you can calculate the latice spacing and miller indices.However, I am unable to understand/visually picture how the dots/rings are obtained from this TEM/diffraction method. Could someone explain me with some basic visual concepts using a unit cell and interacting/diffracting electrons and this shape formations?
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
13K
  • · Replies 35 ·
11K
  • · Replies 21 ·
  • · Replies 152 ·
11K
