Self inductance Griffiths problem
But otherwise, yes, your solution is correct, and the self-inductance can be calculated using the given equation. In summary, the self-inductance of the hairpin loop shown in the figure can be calculated by assuming a tiny radius for the wire and neglecting any flux through the wire itself. The self-inductance is equal to \frac{\mu_{0} l}{2 \pi} \ln \frac{d}{\epsilon} .
stunner5000pt
1,461
Griffiths problem 7.23
Copute the self inducatnce of the hairpin loop shown in the figure. (neglect contribution from ends since mosto f the flux comes form the straight section) To get a definite answer , assume the wire has a tiny radius epsilon, and ignore any flux through the wire itself
[tex] \Phi = LI [/tex]
L = self inductance and I is the current through the loop
induced emf is
[tex] \epsilon = - L \frac{dI}{dt} [/tex]
ok the flux due to straight part on top is (and its legnth is l)
[tex] \Phi = \frac{\mu_{0} Il}{2 \pi} \int_{\epsilon}^{d} \frac{dr}{r} = \frac{\mu_{0} Il}{2 \pi} \ln \frac{d}{\epsilon} [/tex]
due to the bottom wire has the same value
so the total flux is
[tex] \Phi = \frac{\mu_{0} Il}{\pi} \ln \frac{d}{\epsilon} [/tex]
now the self indutance is then
[tex] L= \frac{\mu_{0} l}{2 \pi} \ln \frac{d}{\epsilon} [/tex]
is this correct??
Thanks for the help!
Almost. You have a magical 1/2 that shows up in your expression for L that shouldn't be there.
1. What is self inductance in the context of Griffiths problem?
Self inductance refers to the phenomenon in which a changing current in a circuit induces a voltage in the same circuit. In the context of Griffiths problem, it is used to calculate the magnetic field created by a current-carrying wire.
2. How is self inductance related to the magnetic field?
Self inductance is directly related to the magnetic field, as it is a measure of how much the magnetic field is affected by a changing current. The higher the self inductance, the stronger the induced magnetic field.
3. What is the formula for calculating self inductance in Griffiths problem?
The formula for self inductance in Griffiths problem is L = μ₀N²A/l, where μ₀ is the permeability of free space, N is the number of turns in the wire, A is the cross-sectional area of the wire, and l is the length of the wire.
4. How does the number of turns in a wire affect self inductance in Griffiths problem?
The number of turns in a wire directly affects self inductance in Griffiths problem. As the number of turns increases, the self inductance also increases, resulting in a stronger induced magnetic field.
5. What is the significance of self inductance in practical applications?
Self inductance is an important concept in practical applications, especially in the design and analysis of electronic circuits. It helps engineers and scientists understand and control the behavior of circuits with changing currents, which is essential for the proper functioning of many electronic devices.
  • High Energy, Nuclear, Particle Physics
