A Semicolon notation in component of covariant derivative
berlinspeed
TL;DR Summary
The use of semicolon notation as covariant derivative
Can someone clarify the use of semicolon in
245677
I know that semicolon can mean covariant derivative, here is it being used in the same way (is
245678
expandable?) Or is
245679
a compact notation solely for the components of
245680
If you're familiar with index or abstract index notation
$$S^\alpha{}_{\beta\gamma;\delta} = \nabla_\delta \, S^{\alpha}{}_{\beta\gamma}$$
I know that semicolon can mean covariant derivative, here is it being used in the same way (is View attachment 245678 expandable?) Or isView attachment 245679 a compact notation solely for the components ofView attachment 245680?
Not sure what your confusion is. Any tensor can be written as the sum of each of its components in some basis multiplied by the outer product of the respective basis vectors and co-vectors. Since the covariant derivative of a tensor is still a tensor (but one rank higher), it can also be written this way. Does that clear anything up for you?
Hello thank you, can you tell me what did you use to type your equations? I'm new to this site and trying to find a good way to generate equations. Much appreciated.
Likes vanhees71, JD_PM and berkeman
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
