Separable D.E., Partial Fractions
EtherealMonkey
\frac{dP}{dt}=P-P^{2}
It seems that Partial Fractions should be used to solve this D.E., but I cannot find an example to go by.
I even tried to rewrite the equation as:
\frac{d}{dx}Y\left(x\right)=Y\left(x\right)-Y\left(x\right)^{2}
But, that isn't helping me either...
Anyone?
Please?
I know this may seem so obvious. And, in fact a great deal of my trouble in D.E. so far can be summarized by my "not seeing the forest for the trees".
So, any hint would probably get me going...
This is what I have done so far...
P\left(t\right)\frac{d}{dt}=P\left(t\right)-P\left(t\right)^{2}
P\left(t\right)\frac{d}{dt}=P\left(t\right)\left(1-P\left(t\right)\right)
\frac{1}{P\left(t\right)}dP=\left(1-P\left(t\right)\right)dt
\int \frac{1}{P\left(t\right)}dP= \int dt - \int P\left(t\right) dt
\ln \left(P\left(t\right)\right) = t - \int P\left(t\right) dt
I see you were able to get the 'y' in your user name!
One comment: you're still using the derivative operator incorrectly: d/dt requires something to the right of it, since it means to take the derivative with respect to t of something.
Now, let's look at your DE.
\frac{dP}{dt}~=~P~-P^2
After separation, you get this.
\frac{dP}{P - P^2}~=~dt
Now integrate both sides. You will want to use partial fractions for the integral on the left side, and should get two terms involving ln|P| and ln|1 - P|. Don't forget you'll need the constant of integration.
Is that enough to get you started?
Yes, thank you very much!
Sorry for the late response, I just got on campus.
Now, got to go take a test, wish me much success!
Thanks again Mark!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
