Series Convergence: Does \sum_{k=1}^{\infty }{a_k}^{5/4} Necessarily Converge?
Screwdriver
Say that
\sum_{k=1}^{\infty }a_k
converges and has positive terms. Does the following necessarily converge?
If it necessarily converges, a proof is required, if not, a counter-example is required.
I suspect that it diverges, so I tried an arbitrary geometric series, but it didn't work:
\sum_{k=1}^{\infty }({\frac{1}{k^n}})^{5/4} = \sum_{k=1}^{\infty }({\frac{1}{k^{5n/4}}})
But n must be greater than 1 since ak must converge, and anything greater than 1 times 5/4 is still greater than one, so nothing's been proven.
Alternatively, I could suspect that it will necessarily converge, and use the comparison test:
{a_k}^{5/4}{\leq }^?a_k
{a_k}^{1/4}{\leq }^?1
{a_k}{\leq }^?1
But that's not going to happen in general.
Think about it what means for
<br /> \sum_{k=1}^{\infty }a_k<br />
To converge. What does that imply about a_k? And with that knowledge, what does that entail about a_k ^(c) for c > 1 with relation to a_k?
If
converges, then the terms of the series a_k are approaching zero since
\lim_{x \to 0 }x^c = 0
for c&gt;1. Therefore, the terms of {a_k}^{5/4} are also approaching zero, and they must converge.
Right?
You have the right idea, except you got to use a slightly different argument. After all, if a_k = 1/k, the terms still go to zero, and it all fails.
Try comparison.
But a_k \neq \frac{1}{k} because it was given that the series converges. Should I do something like
{a_k}^{c}\leq^? a_k
{a_k}^{c-1}\leq^? 1
And then argue that this will be true for c > 1 (which is required) because ak converges, so the terms must be approaching zero so they will be less than 1?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
