1MileCrash
- 1,342
- 41
If I want to denote the set of ALL numbers, is the set of complex numbers fitting? a + bi, where b is 0, allows for reals, and where a is 0, allows for imaginary.
What are you looking for? The set of all complex numbers includes all reals and all pure imaginary.1MileCrash said:If I want to denote the set of ALL numbers, is the set of complex numbers fitting? a + bi, where b is 0, allows for reals, and where a is 0, allows for imaginary.
The transcendentals are defined as real numbers that are not algebraic.MrAnchovy said:Now if I mark out a circle with radius [itex]1m[/itex] it will have a circumference of [itex]2 \pi m[/itex] so we need to add the transcendentals too and now we have now got to the reals.
pwsnafu said:The transcendentals are defined as real numbers that are not algebraic. You can't take the algebraic numbers, and union it with the set "real numbers not algebraic" and claim "we now got to the reals".
pwsnafu said:Edit: nothing you post argues we should use reals over p-adics.
MrAnchovy said:However, the mapping of the reals to the points on a line is the clincher for me - the p-adics cannot do this.
jgens said:You realize that there are one-to-one mappings from Rn onto R, right? So all n-tuples of real numbers can be identified with points on a line too. Granted these maps do not preserve algebraic structure, but you never indicated that this was an important point to you.
jgens said:If the fact that R can be identified with points on a line in a way that preserves algebraic structure is what the real clincher is, then R is no more special than Q or R∪{_∞}∪{-∞} or the hyperreal numbers for that matter.
MrAnchovy said:Er, yes it is, Q cannot do that.
MrAnchovy said:Yes you are right. My original statement was "each real number is represented by a point on the line and vice versa", but I ommitted the reverse mapping in my later comment.
checkitagain said:pwsnafu,
aside from the choice of words and phrases of MrAnchovy,
you are not disagreeing with that the set of algebraic numbers
unioned with the set of transcendental numbers equals the
set of Real numbers?
pwsnafu said:The algebraic numbers unioned with transcendentals is equal to the set of all reals.
That is not in contention.
MrAnchovy's used the terms "we got the reals". The connotation is that there's this magical process that let's you go from the algebraics -> real by adding on "numbers which are not algebraic".
That's not how it works. We define the rationals, then use that to construct the reals (using Dedekind or Cauchy). After that we consider the algebraic and transcendentals.
This isn't just theoretical. I was taught in high school "the real numbers are numbers like square root 2 and transcendental numbers like pi". As if that explains anything. :uhh:
micromass said:To be fair, you can define an irrational number as a number whose decimal expansion is non repeating. That is: you can treat real numbers as decimal expansions. That is a third way to construct the reals and it's probably the most honest way. But it's terribly tedious!
Deveno said:you don't even have the full set of rationals to begin with, you just have the ring of all terminating decimals
pwsnafu said:That's not how it works. We define the rationals, then use that to construct the reals (using Dedekind or Cauchy). After that we consider the algebraic and transcendentals.
pwsnafu said:I was taught in high school "the real numbers are numbers like square root 2 and transcendental numbers like pi". As if that explains anything. :uhh:
MrAnchovy said:It is enough (for me) to know that an infinity of numbers that are not algebraic exist to necessitate the extension of my set.
I might use the simpler method of decimal expansion (thanks micromass - and there is no reason to be restricted to base 10 so I don't think Devono's objection is a problem).
MrAnchovy said:I'm not exactly sure whether you are asking one question or two.
If it is one question, no I do not mean 'a real number' because then my statement would indeed have been a ridiculous tautology.
If it is two questions, (i) I am not sure if I can add to the clarity of 'a point on the line'. I am not trying to construct a formal argument, I am trying to explain what the phrase 'all numbers' means to me. And (ii) yes I do mean a real number.
I do appreciate the element of tautology, essentially I am saying that the elements of a continuum map to the elements of a continuum. This is straying from my point however which is the sufficiency (and necessity) of the reals to satisfy my concept of 'all numbers'. I am perfectly willing to accept that you find that ridiculous.
pwsnafu said:How do you know that it needs to be an uncountable set?
MrAnchovy said:I don't need to construct all the reals in order to know that there are some numbers that are not rational
Everything that I have been calling a number can be represented by a point on a line; I know that there are some (infinitely many) numbers (i.e. points on the line) that are not algebraic, so I simply extend my set to all points on the line and call it 'all numbers'.
jgens said:If you assume a priori that certain numbers like √2 and π exist then you can show that there are some numbers that are not rational. But formally you need to construct them in the first place before you can really talk about them at all.
jgens said:Why do you assume that a line is best modeled by R? Non-standard models of R ought to be perfectly good candidates too.
jgens said:How are decimal expansions more simple or natural? Mathematicians rarely use the fact that the real numbers have decimal representations. The important properties that most mathematicians use are better captured in the constructions via Dedekind cuts or equivalence classes of Cauchy sequences.
MrAnchovy said:I disagree. I don't have to assume that √2 exists, I can see it when I look at the diagonal of a unit square. Formal construction of √2 from a set of axioms is not necessary for me to talk about it - much less for me to understand it
However there are some transcendentals for which I would argue the opposite (in fact there exist uncountably many such numbers between any two numbers that I do understand)
Jamma said:Was my question not simple enough as it is? If you can't "add to the clarity of a point on the line", then your post is meaningless, because I don't know what you mean by a point on the line.
jgens said:I never meant that you cannot talk about √2 without a formal construction. I did mean that without a formal construction you have to assume that it exists a priori. Whether or not you consider this a problem is a matter of personal taste. But in my view, without the formal construction, you cannot be certain that you are actually saying anything.
jgens said:... These are the reasons that I do not like talking about things without formal constructions.
jgens said:But I am not sure what it would mean to have an understanding of uncountably many individual transcendental numbers, especially since there are only countably many computable real numbers.
micromass said:I don't really see why this must be true.
Real numbers are numbers that can be found on a number line and can be represented by decimal or fractional values. They include both positive and negative numbers, as well as zero.
Imaginary numbers are numbers that cannot be found on a number line and are represented by the imaginary unit, i. They are often used in complex numbers and have the form bi, where b is a real number and i is the imaginary unit.
The set of all real numbers, denoted by R, is the set that contains all possible real numbers. It includes all rational and irrational numbers, such as integers, fractions, decimals, and square roots.
The set of all imaginary numbers, denoted by I, is the set that contains all possible imaginary numbers. It includes all numbers of the form bi, where b is a real number and i is the imaginary unit.
Real and imaginary numbers are often used together in complex numbers, which have the form a + bi, where a is a real number and bi is an imaginary number. They are also used in mathematical operations, such as addition, subtraction, multiplication, and division.
