Set of functions that are eventually zero
jmjlt88
The problem asks whether the set F of all functions from Z+ into {0,1} that are "eventually zero" is countable or uncountable.
In my proof, I claimed countable. By definition, associated with each function f in F, there is a positive integer N such that f(n)=0 for n≥N. I took N' to be the largest of these N's. Hence, for each f in F, f(n)=0 for all n≥N'. Then, I defined a function g: F -> {0,1}N'-1 by
g({(1,x1),...,(N'-1,xN'-1), (N',0),(N'+1,0)...}) = (x1,...,xN'-1)​
[Note: I know there is a simplier way to denote elements in F]
I then proved that this is a bijection. Since the range is a finite product of countable sets, it is countable. It follows that F is indeed countable.
Looking back at my proof, I feel that I may have made an error in picking N'. Cannot I not just construct a function that sends 1 through, say, N'+1 to 1 and the rest to zero? In other words, what (if anything) allows me to pick such an N'?
My proof may be correct. That is, I may be second guessing myself.
jmjlt88 said:
The problem asks whether the set F of all functions from Z+ into {0,1} is countable or uncountable.
What about f(n)=1 for all n in Z+?
Or g(n)=1 for odd n, g(n)=0 for even n?
If that N(f) would exist for all f in F, F would be countable. However, you would need a different proof:
"The largest N" does not have to exist in infinite subsets of the natural numbers.
If that N' would exist, F would be finite.
Sorry. I posted the question wrong. The problem asks whether the set F of all functions from Z+ into {0,1} that are eventually zero is countable or uncountable.
You can't choose a largest N' at all. Each function has a different N, no reason they should be bounded. Take the set of all functions such that f(n)=0 for n≥N. That's countable (in fact, it's finite). Now think about forming a union of sets.
I knew that picking N' was wrong! :frown: It didn't sit right with me. What about this.
Let AN be the set of all functions such that f(n)=0 for n≥N. For THIS set, I can construct a bijective correspondence between AN and {0,1}N-1 by defining g: AN->{0,1}N-1 by
g({(1,x1),...,(N-1,xN-1), (N,0),(N+1,0)...}) = (x1,...,xN-1).
Hence AN is countable for each N.
Taking Z+ as our index set. The union of all AN for each NεZ+ is the countable union of countable sets ...
Yes, that would do it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
