Set of functions that is eventually zero
The discussion clarifies the concept of functions f: N → {0,1} that are "eventually zero," meaning they eventually consist solely of zeros after a certain point. Participants confirm that these functions can be interpreted as binary sequences where, after a finite number of 1's, the sequence continues with 0's indefinitely. The correct way to visualize this is by reading the sequence from left to right, not right to left. Thus, a binary sequence is considered eventually zero if it contains only a limited number of 1's. Understanding this concept is essential for solving related homework problems.
Marioqwe
Usually, in homework problems, I come across something like, "Let F be the set of all functions f:\mathbf{N}\rightarrow\{0,1\} that are eventually zero."
But I don't really understand what is meant by that. Is it right to think about it as the set of binary numbers? If I take each f to be a sequence of 0's and 1's and I read them from right to left then they are eventually zero right? I'm not sure this is the right way of thinking about this.
Mathematics news on Phys.org
Hi Marioqwe! :smile:
Marioqwe said:
… If I take each f to be a sequence of 0's and 1's and I read them from right to left then they are eventually zero right?
yes
an f:N -> {0,1} is a sequence of 0s and 1s
for example, 110110100100000000000000…
if it ends with all 0s after some time ("zero recurring"), then it is eventually zero :wink:
Did you mean left to right? That's how to think of this. Another way to say it is that a binary sequence is eventually zero if it contains only finitely many 1's.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
