Set theory problem (uncountable set)
quasar987
I would like to show that if we have a non-negative real valued function f defined on f a set X, and that the set of points where f is non-vanishing is uncountable, then for any M > 0, I can find a sequence {x_n} of points in X such that
\sum_n f(x_n)>M
This is not for a set theory class, its in the context of a measure and integration problem where I want to demonstrate a necessary and sufficient condition for a function to be integrable on a set X with respect to the cardinal measure mu(E) = |E|.
Ok, so I would appreciate to get a confirmation that the following assertion is true, because if it is, then I will have solved the problem I think:
"If for any natural number n,
f^{-1}(]\frac{1}{n}, +\infty[)
is countable, then
f^{-1}(]0, +\infty[)
is countable too."
It seems so to me since it seems natural that a countable union of countable sets in countable and
\bigcup_{n\geq 1} f^{-1}\left(]\frac{1}{n}, +\infty[\right) = f^{-1}\left(\bigcup_{n\geq 1}]\frac{1}{n}, +\infty[\right)=f^{-1}(]0, +\infty[)Thx.
A countable union of countables is countable: #(N x N) = #N.
sweet. By the end of the thread I didn't really had a doubt left but thanks for confirming, and so fast!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
