Proving Properties of Open Sets in Real Numbers
In summary, the conversation discusses the definition of an open subset in the context of real numbers. It is stated that a subset U is open if for every x in U, there exists an open interval (a, b) such that x is a subset of (a, b) and (a, b) is a subset of U. The first part of the discussion (a) focuses on proving that the numbers a and b in this definition can be taken as rational, and the second part (b) discusses how any open set U can be expressed as a union of possibly infinitely many intervals with rational endpoints. The final part (c) poses the question of how many open subsets of R exist.
saadsarfraz
86
A subset U [tex]\subseteq[/tex] R is called open if, for every x [tex]\in[/tex] U, there is an open interval (a, b) where x [tex]\in[/tex] (a, b) [tex]\subseteq[/tex] U.
(a) Show that, in the above de definition, the numbers a, b may be taken
as rational; that is, if x [tex]\in[/tex] U, there is an open interval (c, d) where
x [tex]\in[/tex] (c, d) [tex]\subseteq[/tex] U and where c, d [tex]\in[/tex] Q.
(b) Show that any open set U is a union of (possibly in finitely many)
intervals (a, b) where a, b [tex]\in[/tex] Q.
(c) How many open subsets of R exist?
i don't have much idea, the idiot prof hasnt even covered most of the stuff in class.
For (a), let m := (b - a) / 2 be the midpoint of the interval. Do there exist rational numbers c and d such that a < c < m < d < b?
For (b), here's a hint:
[tex]U = \bigcup_{x \in U} x[/tex].
Hi, thank you for the hints but I am still stuck on part c. any ideas?
I take it that means that you did a and b.
I haven't given c much though myself. You could start by counting how many open intervals there are, for which it suffices to count intervals of the form (c, d) with c and d rational. Then how many unions can you take?
1. What is an open set in real numbers?
An open set in real numbers is a set of numbers in which every element can be surrounded by a neighborhood that is also contained within the set. In other words, an open set is a set of numbers that does not include its boundary points.
2. How do you prove that a set is open in real numbers?
To prove that a set is open in real numbers, you can show that for every point in the set, there exists a neighborhood around that point that is also contained within the set. You can also prove this by showing that the set does not include any of its boundary points.
3. What is the difference between an open set and a closed set in real numbers?
An open set in real numbers does not include its boundary points, while a closed set includes all of its boundary points. In other words, there is no overlap between the elements in an open set and its boundary points, while there is overlap in a closed set.
4. Can a set be both open and closed in real numbers?
Yes, a set can be both open and closed in real numbers. This type of set is known as a clopen set. An example of a clopen set is the empty set, which does not contain any elements and therefore does not include any of its boundary points.
5. How does the concept of open sets relate to continuity in real numbers?
The concept of open sets is closely related to the concept of continuity in real numbers. A function is considered continuous at a point if the inverse image of an open set containing the output of that point is an open set containing the input of that point. This means that in order for a function to be continuous, it must preserve the openness of sets between its input and output.
