Setting up a work problem. pumping gasoline
4 replies · 5K views · last reply
bakin
I just have a quick question. I'm supposed to find the work required to pump gas out of a cone, but am having trouble finding the radius of the cone.
The cone measures 10 feet in height. I broke it up and set it up using similar triangles, and this is what I got:
Left: an upright cone with its point down, height labeled 10, top radius labeled x. Right: a cross-section triangle with top side x, a horizontal slice at height labeled r(x), and height 10. Text: r(x)/x = y/10 and r(x) = xy/10.
It doesn't seem right though. And, if it is right, where do I go from there? Any help is appreciated :)
if the height is 10, then y must be the difference from 10, or is that straight from the book?
Ok here is the full problem.
Gasoline weighing 42lb/ft(cubed) is contained in a buried conical tank shown below. (above). Set up an appropriate integral, and find the work required to pump all the gas to ground level.
The tank is 5 feet below ground, i just didn't draw it on the diagram.
edit: so do you think it's 10-y ?
Because 10 is the height of the cone. I'm trying to find the radius of the cone. I know how to do the pumping problems, but I'm just stuck on how to find the radius that you'll end up plugging into the integral.
I don't think I have all the information for the problem. I did a similar problem that gave me the radius of the top of the tank and I was able to do it. I'll check tonight to see if I'm missing something.
