Determine Maximum Magnitude P for Shear Stress of Beam
The discussion focuses on determining the maximum load P that a beam can support without exceeding an average shear stress of 80 MPa in the pins, which have a diameter of 18 mm. A key point raised is the misunderstanding regarding the support reaction at joint B, where it is clarified that B_y is not an external support but rather the vertical component of the force in the link. The participant is advised to eliminate the extra term related to B_y to correctly solve for P. Additionally, it is suggested to verify that the pin at A does not limit the design. The conversation emphasizes the importance of accurately accounting for forces in structural analysis.
Chibus
Question 3: The beam is supported by a pin at A and a short link BC, as shown in Figure 3.0. Determine the maximum magnitude P of the loads the beam will support if the average shear stress in each pin is not to exceed 80 MPa. The diameter for each of the pins is 18 mm.
http://img13.imageshack.us/img13/7517/chibusq3.jpg
http://img5.imageshack.us/img5/1824/chibus1.jpg
http://img13.imageshack.us/img13/9589/chibus2.jpg
I just wanted to get an idea if I'm way off. Really I don't know how to proceed past finding the required shear force in the pins to shear them.
PS: Sorry for my horrible english and writing skills.
Hello, Chibus, welcome to PF! You are making an error in assuming that there is a support reaction B_y at joint B. There is no external support there. B_y is just the vertical component of the force in the link. Don't add it in twice. Otherwise, your method looks OK, and you should be able to solve for P when you eliminate that extra term. Also, be sure to check that the pin at A does not control the design.
