Calculate Forces on Tools & Workpieces in Sheet Metal Spinning
Calculating the forces on tools and workpieces in sheet metal spinning can be approached theoretically or through software like SolidWorks. Accurate modeling is crucial, requiring precise dimensions and material selections, followed by using the Simulation package to analyze forces. ANSYS is also suggested as a viable alternative for this type of analysis. It's important to use a powerful computer for simulations, as they can be time-consuming. Exploring these software options will aid in understanding the forces involved in the process.
nrbhyagrwl
Hi I am a Mechanical Engineering final year student from India.
I need to calculate the forces(axial,tangential and radial) on the tool and the workpiece in the sheet metal spinning operation.
Is there someway to find it theoretically or using any software?
thanks
The only thing that comes to mind is by using SolidWorks. You could see if your school has this program available at your disposal because it costs quite a bit. You would first need to model extremely precisely getting all the dimensions, material selections, etc. correct. Then use the Simulation package that is an add-in for SolidWorks to simulate the forces seen by an applied load or whatever is occurring to that particular tool and/or workpiece. Below is a link that shows you a video on how to simulate. I apologize if you knew about this already and sorry for wasting your time. Best of luck!
p.s. make sure you use a pretty fast and powerful computer when performing the simulation run function because it takes quite a bit of time otherwise.
http://www.youtube.com/watch?v=LzSnGkpRITY&feature=related
Thanks a lot :), will try that and tell you...
you could also see is ANSYS would do the job!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
