How do I calculate the period for a system with 2 springs and 1 mass in series?
  • Thread starter Thread starter Matt1234
    Mass Shm
To calculate the period for a system with two springs and one mass in series, the effective spring constant must be determined using Hooke's law. When springs are in series, they share the same tension, which affects how their forces are summed. In part A of the problem, the forces of the springs are summed since they act in the same direction, while in part B, the forces are subtracted as they act in opposite directions. The net force on the mass is the sum of the forces from each spring when it moves. Understanding these principles is essential for solving the problem accurately.
Matt1234
[PLAIN]http://img24.imageshack.us/img24/2706/64505257.jpg
t = 2pi * Sqrt(m/k)
Im not very sure how to proceed with this one. I have tried calculating the peroid for 2 separate cases and then adding them together but it didnt seem to give the same result as the question. I am not looking for the answer, instead some direction on how to obtain it. I have also tried starting from hookes law.
Use Hooke's law to figure out the effective spring constant in each case.
EDIT: Note there should be a + in between kx1 and kx2, sorry.
Hi there, thank you for your reply.
I tried as you suggested and oddly enough proved part B. I don't understand why though, in part a the force of the springs should be summed because there in the same direction where as in part b they should be subtracted because there in opposite direction.
[PLAIN]http://img262.imageshack.us/img262/3219/lastscanmz.jpg
In part a each spring has the same tension, since they are in series (and presumably massless). You'll need to use that fact to figure out the effective spring constant for springs in series.
In part b, when the mass moves to the right (for example) both springs exert a force on it to the left. So the net force on the mass is the sum of the forces of each spring.
