SHM and Conservation of Energy/Momentum
The discussion revolves around a physics problem involving a spring, two masses, and the conservation of energy and momentum. The scenario describes a 2kg block on a frictionless table that collides inelastically with a 150g mass moving at 7m/s, compressing the spring over 0.4 seconds. Participants express confusion about calculating the maximum force of contact post-collision and how to apply the conservation principles effectively, particularly regarding the spring constant and compression. There's a need to clarify the relationship between energy, velocity, and impulse in this context. The consensus suggests starting with the inelastic collision to simplify subsequent calculations involving the spring.
badatphysics2
One end of a spring is attached to a wall to a block of mass X= 2kg (on a frictionless horizontal table). Another mass M of 150g moving at a speed of 7m/s collides (inelastic). This takes 0.4s to compress the spring to its max compression.
I have to find the max force of contact between X and M after the collision. And then the energy of the system when the force between the masses is half this max value.
0.5kx^2
0.5mv^2 = 11.025 m/s (for mass M)
m1v1=m2v2
p=m*v
T = 1.6s (since it takes 0.4s for 1/4 of the period)
I know energy will be conserved, so the energy from the spring, and from the mass X is needed. However, since the spring constant k, and the amount it's compressed by isn't given, I'm not sure how to do 0.5kx^2. I'm confused with what the 'max force of contact' between the two masses is. Is that considered impulse? I think I'd have to find the velocity of the two combined during the collision, and then using conservation to find the velocity after it?
But I'm not sure...how to relate them.
How can an energy be equal to a velocity?
badatphysics2 said:
m1v1=m2v2
What are m1, v1, m2, v2?
Where? Everywhere?
Start with the correct time order, i. e. the inelastic collision first. That will make the second part with the spring easier.
