How Do Astronauts Measure Their Mass in Space?
  • Thread starter bobbarkernar
  • Tags
    Shm
In summary: And T should be 3 since the period is 3 seconds, as indicated by the figure. So when the position is 1.2m, what is the corresponding time? Once you have that, plug it into your velocity equation and you will have your answer.In summary, astronauts in space determine their mass by oscillating on a large spring rather than standing on a bathroom scale. To find the speed of an astronaut attached to a spring, one can differentiate the position equation and plug in the corresponding time at a given position. In this case, the period is 3 seconds and the position is 1.2m, so the speed can be found by differentiating 1+0.4sin((2pi/3)t
bobbarkernar
48
Astronauts in space cannot weigh themselves by standing on a bathroom scale. Instead, they determine their mass by oscillating on a large spring. Suppose an astronaut attaches one end of a large spring to her belt and the other end to a hook on the wall of the space capsule. A fellow astronaut then pulls her away from the wall and releases her. The spring's length as a function of time is shown in the figure.
http://session.masteringphysics.com/problemAsset/1001073/9/knight_Figure_14_36.jpg
What is her speed when the spring's length is 1.2 ?
i tried to write the position as x(t)= .6+1.4sin((2pi/T)t)
The center of the sine wave is at 1.0m, not at 0.6m
Re-write the position equation with a number for T, then differentiate and figure out what phase to plug into the velocity equation. You're good to go!
Yes...Keep going. To find the speed you have to differentiate your equation, find the time corresponding to a position of 1.2 , plug that time in your equation for the velocity and get your answer. (you may read the period T from your figure)
Patrick
EDIT: I just noticed on the figure that the oscillation is from 0.6 to 1.4, so the equation should be [itex] 1+ 0.4 sin ({2 \pi \over T} t ) [/itex]
so i should differentiate [itex] 1+ 0.4 sin ({2 \pi \over T} t ) [/itex]
for t and Tshould be 3??
Yep, that's the next step.
Related to How Do Astronauts Measure Their Mass in Space?
What is the "SHM problem" that astronauts face?
The SHM (Space Head-Movement) problem is a phenomenon experienced by astronauts when they are in microgravity environments, such as in space. It occurs when the fluid in the inner ear, which is responsible for balance and orientation, is not affected by gravity and can cause disorientation, dizziness, and motion sickness.
How does the SHM problem affect astronauts?
The SHM problem can significantly impact an astronaut's ability to perform tasks and adapt to the microgravity environment. It can cause nausea, loss of coordination, and difficulty navigating through the spacecraft. It can also affect their overall well-being and mental state.
What measures are taken to prevent or mitigate the SHM problem?
Astronauts undergo extensive training and simulations to prepare for the SHM problem. They also use various devices, such as virtual reality headsets and rotating chairs, to help them adapt to microgravity. Additionally, astronauts can take medication to alleviate symptoms and use special equipment, like body restraints, to stabilize themselves during tasks.
Can the SHM problem be permanently solved?
Currently, there is no permanent solution to the SHM problem. However, researchers are continuously studying the effects of microgravity on the human body and developing new techniques and technologies to mitigate its effects. In the future, advancements in artificial gravity and space travel may help prevent or minimize the SHM problem.
Is the SHM problem only experienced by astronauts?
No, the SHM problem is not limited to astronauts. It can also affect individuals who participate in parabolic flights, which simulate microgravity conditions on Earth for research purposes. Additionally, individuals with vestibular disorders or inner ear problems may also experience similar symptoms in microgravity environments.
15K
15K
