Deriving the Equation for Spring Deflection of a Dropped Mass
  • Thread starter Thread starter rotin089
    Mass Shm
The discussion focuses on deriving the equation for spring deflection (x) when a mass (M) is dropped from a height (z) onto a spring with stiffness (k). It emphasizes the conservation of mechanical energy, where potential energy (PE) and kinetic energy (KE) are considered. Participants suggest setting up an energy balance equation that incorporates x, z, M, g (acceleration due to gravity), and k. The goal is to express x as a function of these parameters without solving the equation. Ultimately, the conclusion is that x depends on mass, gravitational acceleration, and spring stiffness.
rotin089
i have the following question and i have no idea how to answer it can any please help out...
consider a Mass M which is dropped a height z onto a spring of stiffness k N/m. when the mass hits the spring, the spring will deflect a distance x before the mass stops moving down. show that the distance x is a function of the mass M, acceleration due to gravity g and of stiffness of the spring k.
please help
Hint: Is anything conserved?
energy both pe and ke
The total mechanical energy is conserved. Use that to set up an energy equation to solve for X.
i do not need to solve the equation. i need to find the derivative of the equation. i need to conclude that x is a function of the mass M, acceleration due to gravity g and of stiffness of the spring k.
Set up the energy balance equation--which will involve x, z, M, g, and k--then you can rearrange to get x as a function of the other parameters. (That's what I mean by 'solving for x'.)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
